| Mylyn WikiText Stand-Alone Package Available [message #61619] |
Tue, 11 November 2008 11:51  |
David Green Messages: 135 Registered: July 2009 |
I'm pleased to announce that the Mylyn WikiText stand-alone package is
available for download (http://www.eclipse.org/mylyn/downloads/). The
download contains jar files and documentation for including WikiText Ant
tasks in your build or for using WikiText APIs outside of an Eclipse
runtime.
The WikiText project is still in the incubation phase, thus users should
be aware that the download has not yet completed a release review. The
availability of WikiText stand-alone download enables users to try out
WikiText prior to its release, including the much-anticipated
wiki-to-DITA functionality.
This is the first time that WikiText stand-alone jars have been made
available since the move of Textile-J to the WikiText project. WikiText
includes many improvements and fixes since the Textile-J 2.2 release.
Many thanks to Mik Kersten, Steffen Pingel and others at Tasktop who
have facilitated the WikiText project.
| Re: WikiText (textile) Markup Question [message #62227 is a reply to message #61960] |
Tue, 25 November 2008 17:08   |
Philip Quitslund wrote:
> Forgive me if this is the wrong forum for this but I haven't seen a more
> appropriate group. Please redirect if I've mis-fired!
This is the right place
> Anyway, I have a
> really simple textile markup question. I'm playing with it as a source
> for my HTML files and am puzzling over how to set a document's title
> (changing the document name is not an ideal option).
As far as I am aware, none of the markup languages supported by WikiText
have syntax for setting the document title. (Textile, MediaWiki,
Confluence, TracWiki and TWiki)
> Inserting this at the beginning of the file:
> <title>Version History</title>
> "works" (sort of), in the sense that it renders correctly (FireFox
> anyway) but the generated markup is not quite right. As you'd expect,
> the title is injected into the body and not into the head:
> <head></head>
> <body>
> <p><title>Version History</title></p>
That's a side-effect of lenient browsers, and this is not really
best-practice (as you noticed)
> So... Is there a more proper way to do this? Is this something I need
> to do in the build phase (e.g., like the <stylesheet> entries in the
> online ant example)? If so, do you have any concrete examples?
The way to do this is via the Ant task. You can specify the title as an
attribute as follows:
<wikitext-to-html markupLanguage="Textile" title="My Title"
file="docs/my-file.textile">
<stylesheet url="docs/styles/main.css"/>
</wikitext-to-html>
I hope that helps.
| Re: WikiText (textile) Markup Question [message #62298 is a reply to message #62227] |
Tue, 25 November 2008 18:02  |
Philip Quitslund Messages: 24 Registered: July 2009 |
Junior Member |
Hey David,
I think you're right. A bit surprising but not that big of a deal.
> </wikitext-to-html>
This is just what I thought.
> I hope that helps.
It does.
Many thanks!
-phil
| WikiText (textile) Markup Question [message #594889 is a reply to message #61619] |
Wed, 19 November 2008 18:24  |
Junior Member |
appropriate group. Please redirect if I've mis-fired! Anyway, I have a really
simple textile markup question. I'm playing with it as a source for my HTML
files and am puzzling over how to set a document's title (changing the document
"works" (sort of), in the sense that it renders correctly (FireFox anyway) but
the generated markup is not quite right. As you'd expect, the title is injected
<head></head>
<body>
So... Is there a more proper way to do this? Is this something I need to do in
the build phase (e.g., like the <stylesheet> entries in the online ant example)?
Any pointers appreciated!
-phil
| Re: WikiText (textile) Markup Question [message #595005 is a reply to message #61960] |
David Green Messages: 96 Registered: July 2009 |
Member |
> Anyway, I have a
> <head></head>
> <body>
</wikitext-to-html>
I hope that helps.
| Re: WikiText (textile) Markup Question [message #595031 is a reply to message #62227] |
Junior Member |
Hey David,
> </wikitext-to-html>
> I hope that helps.
It does.
Many thanks!
-phil
FUDForum. Page generated in 0.01991 seconds
