Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF object serialization into xml
EMF object serialization into xml [message #622837] Thu, 06 May 2010 09:21 Go to next message
Ugur Kocak is currently offline Ugur Kocak
Member
Hi I have a problem in serializing my EMF objects to a XML file.
I want to serialize all Objects but my program create a xml file with only one object in it.
Look on my code:
public void serialize() throws IOException {
ResourceSet rs = new ResourceSetImpl();
// Register the base XML resource factory implementation in the local resource factory registry.
rs.getResourceFactoryRegistry().getExtensionToFact oryMap().put( "xml", new XMLResourceFactoryImpl());
URI fileURI = URI.createFileURI( FILE.getAbsolutePath());
Resource resource = rs.createResource( fileURI);
// serialize all ComputerResources objects into xml
Iterator<ComputerResources> itr = ComputerCollectionGenerator.computerResoucres.iter ator();
while ( itr.hasNext()) {
ComputerResources next = itr.next();
resource.getContents().add( next);
resource.save( null);
The objects are created and stored at runtime in ArrayList computerResoucres.
What do I have to do?
Thank you in advance
Re: EMF object serialization into xml [message #622838 is a reply to message #622837] Thu, 06 May 2010 09:32 Go to previous message
Cyril Jaquier is currently offline Cyril Jaquier
Member
A XMLResource can only contain a single root element. Use a XMIResource
instead.
The easiest way to do it is 1/ register XMIResourceFactoryImpl with the
".xmi" extension and 2/ end your URI with ".xmi". That's it :-)
Cyril
Previous Topic:[EMF Compare] Duplicate move detection
Next Topic:EMF Compare NPE
Current Time: Sat May 18 12:02:44 EDT 2013
Powered by FUDForum. Page generated in 0.01479 seconds
