Home » Eclipse Projects » Platform - User Assistance (UA) » org.dita.dost.contentProducer prevents plugin from loading
org.dita.dost.contentProducer prevents plugin from loading [message #621663] Thu, 30 October 2008 09:54
Mike Melton is currently offline Mike Melton
Member
When I generate Eclipse Help from Astoria, the resulting plugin somtimes
references org.dita.dost.contentProducer in plugin.xml, which prevents the
Eclipse Help plugin from loading.
<?xml version="1.0" encoding="utf-8" ?>
<plugin name="Schnelleinstieg für die Lizenzierung"
id="com.xxx.proddoc.productname.DE" version="1.0" provider-name="DITA">
<requires>
<import plugin="org.dita.dost.contentProducer" />
</requires>
<extension point="org.eclipse.help.toc">
<toc file="GettingStartedLicensing.xml" primary="true" />
</extension>
<extension point="org.eclipse.help.contentProducer">
<contentProducer producer="org.dita.dost.ContentProducer" />
</extension>
</plugin>
When I remove <requires>.....</requires> and the extension point for
org.dita.dost.contentProducer, the plugin loads just fine. Can anyone tell
me what this contentProducer is?
Previous Topic:Standalone Help startup time, precompiled JSPs?
Next Topic:add files that do not lay in project folder
Current Time: Mon May 20 12:12:59 EDT 2013
Powered by FUDForum. Page generated in 0.01861 seconds
