Home » Eclipse Projects » JavaServer Faces » Eclipse POJO Wizards
Eclipse POJO Wizards [message #621240] Wed, 05 May 2010 06:53 Go to next message
Carlos Conti is currently offline Carlos Conti
Hi there,
is there such a thing? I am not developing in EJB standard, but using POJO's as JavaBeans to hold data between user interface and backend database.
Is there any pluggin or tool I have not discovered yet that for every property you can define :
[datatype]
[propertyName]
and get it automatically generated for a class?
If only available in UML related code generators, I think it will get too complicated.
Thanks for your help.
Carlos.
Re: Eclipse POJO Wizards [message #621241 is a reply to message #621240] Wed, 05 May 2010 09:28 Go to previous message
Yury Kats is currently offline Yury Kats
On 5/5/2010 6:53 AM, Carlos Conti wrote:
> Hi there,
> [datatype]
> [propertyName]
I don't think there is a wizard like this. But you can
1) use a wizard to create a Java class
2) define class properties in the body of the class, as datatype propertyName;
3) have Eclipse generate class c'tors and getters/setters for all of the properties.
Previous Topic:JavaServer Faces 2.0
Next Topic:Eclipse POJO Wizards
Current Time: Tue May 21 04:43:42 EDT 2013
Powered by FUDForum. Page generated in 0.01716 seconds
