Home » Eclipse Projects » JavaServer Faces » JSF 2.0 Facelets content assist not working
JSF 2.0 Facelets content assist not working [message #621231] Sat, 20 February 2010 00:41 Go to next message
Jaya  is currently offline Jaya
I, ve some trouble with JSF Facelets Tools Project.
I've installed the facelet plugin in eclipse gynamede and created a new Facelet Web Dynamic Project.
I did the login example.Everything works fine.But the problem is when i click <h: ctrl +spacebar the content assist is not coming in the pages.
A warning message
Can't find facelet tag library for uri http://java.sun.com/jsf/
core
Can't find facelet tag library for uri http://java.sun.com/jsf/html
facelets is shown in the following line:
<html xmlns="http://www.w3.org/1999/xhtml"
xmlns:ui="http://java.sun.com/jsf/facelets"
xmlns:h="http://java.sun.com/jsf/html"
xmlns:f="http://java.sun.com/jsf/core">
I followed the steps in the webinar session Building Facelets Applications with the JSF Tools for Eclipse.All the libraries are in place.
Anyone know the solution?
Re: JSF 2.0 Facelets content assist not working [message #621232 is a reply to message #621231] Wed, 24 February 2010 12:28 Go to previous messageGo to next message
Cameron Bateman is currently offline Cameron Bateman
Hi Jaya,
JSF 2.0 is not yet supported in JSF Tools. We are working on adding it for Helios. Stay tuned in this forum for updates. If you are an adopter, you can also search [JSF2.0] in the Eclipse bug database both in summary title and whiteboard field of WebTools->JSF Tools product bugs.
Cameron Bateman
JSF Tools Committer
Re: JSF 2.0 Facelets content assist not working [message #621233 is a reply to message #621231] Wed, 24 February 2010 12:31 Go to previous message
Note also that the Facelet incubator plugins are being folded into the main tooling as part of adding support for JSF 2.0. We will support the similar backward compatibility for Facelets 1.x as is supported in the runtime spec, but no further work will be done on the incubator plugins.
Previous Topic:JSF 2.0 Facelets content assist not working
Next Topic:Support fro JSF 2.0 in WTP Helios release..
Current Time: Tue May 21 16:47:11 EDT 2013
Powered by FUDForum. Page generated in 0.03259 seconds
