Home » Eclipse Projects » JavaServer Faces » Exception when using the JSF Facelets Tools Incubator
Exception when using the JSF Facelets Tools Incubator [message #476138] Fri, 15 May 2009 17:43 Go to next message
M. Hansen is currently offline M. Hansen
I'm using RAD 7.5.2 which is based on Eclipse 3.4. I get the following
exceptions when I try to get auto completion on tags in my xhml page. I'm
not able to get any auto completion on any tags (not even regular html
tags). I have followed the tutorial at
http://download.oracle.com/docs/cd/E14545_01/help/org.eclips e.jst.jsf.facelet.doc.user/html/gettingstarted/tutorial/JSF% 20Facelets%20Tools%20Tutorial.html.
Are anyone else seeing these exception? Any idea to what is going on?
Any help would be appreciated.
Thank
M. Hansen
java.lang.NoSuchMethodException:
com.sun.facelets.tag.jstl.fn.JstlFnLibrary.getNamespace()
at java.lang.Class.throwNoSuchMethodException(Unknown Source)
at java.lang.Class.getMethod(Unknown Source)
org.eclipse.jem.internal.proxy.ide.IDEBeanTypeProxy.getMetho dProxy(Unknown
Source)
org.eclipse.jst.jsf.core.internal.jem.BeanProxyUtil$BeanProx yWrapper.call(Unknown
Source)
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.taglib.Li braryClassBasedTagRecord.resolveNS(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.taglib.Li braryClassBasedTagRecord.initURI(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.taglib.Ta gRecordFactory.createRecords(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.taglib.Ja rFileFaceletTaglibLocator.findInJars(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.taglib.Ja rFileFaceletTaglibLocator.locate(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.taglib.Pr ojectTaglibDescriptor$1.run(Unknown
Source)
at org.eclipse.core.runtime.SafeRunner.run(Unknown Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.taglib.Pr ojectTaglibDescriptor.initialize(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.taglib.Pr ojectTaglibDescriptor.getTagLibraries(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.FaceletTa gRegistry.initialize(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.FaceletTa gRegistry.getAllTagLibraries(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.registry.FaceletTa gRegistry.getTagLibrary(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.cm.FaceletDocument Factory.getOrCreateCMDocument(Unknown
Source)
org.eclipse.jst.jsf.facelet.core.internal.cm.FaceletDocument Factory.createCMDocumentForContext(Unknown
Source)
org.eclipse.jst.jsf.facelet.ui.internal.contentassist.XHTMLC ontentAssistProcessor.getAvailableChildElementDeclarations(U nknown
Source)
org.eclipse.wst.xml.ui.internal.contentassist.AbstractConten tAssistProcessor.addTagNameProposals(Unknown
Source)
org.eclipse.wst.xml.ui.internal.contentassist.AbstractConten tAssistProcessor.computeTagOpenProposals(Unknown
Source)
org.eclipse.wst.xml.ui.internal.contentassist.AbstractConten tAssistProcessor.computeCompletionProposals(Unknown
Source)
Source)
org.eclipse.jst.jsf.facelet.ui.internal.contentassist.XHTMLC ontentAssistProcessor.computeCompletionProposals(Unknown
Source)
org.eclipse.wst.sse.ui.internal.contentassist.CompoundConten tAssistProcessor.computeCompletionProposals(Unknown
Source)
org.eclipse.jface.text.contentassist.ContentAssistant.comput eCompletionProposals(Unknown
Source)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .computeProposals(Unknown
Source)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .access$16(Unknown
Source)
org.eclipse.jface.text.contentassist.CompletionProposalPopup $2.run(Unknown
Source)
at org.eclipse.swt.custom.BusyIndicator.showWhile(Unknown Source)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .showProposals(Unknown
Source)
at org.eclipse.jface.text.contentassist.ContentAssistant$2.run( Unknown
Source)
at org.eclipse.swt.widgets.RunnableLock.run(Unknown Source)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Unknow n Source)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.ui.internal.Workbench.runEventLoop(Unknown Source)
at org.eclipse.ui.internal.Workbench.runUI(Unknown Source)
at org.eclipse.ui.internal.Workbench.access$4(Unknown Source)
at org.eclipse.ui.internal.Workbench$5.run(Unknown Source)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Unknown
Source)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Unkn own Source)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(Unknown Source)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (Unknown
Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Unknow n Source)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(Unknown
Source)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Unknown
Source)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Unknown Source)
at org.eclipse.equinox.launcher.Main.basicRun(Unknown Source)
at org.eclipse.equinox.launcher.Main.run(Unknown Source)
at org.eclipse.equinox.launcher.Main.main(Unknown Source)
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.LinkageError: loading constraint violation: loader
"org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader@2d732d73"
previously initiated loading for a different type with name
"org/eclipse/wst/xml/core/internal/contentmodel/CMDocument" defined by
loader "org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader@2230223")
at org.eclipse.swt.SWT.error(Unknown Source)
Source)
Source)
Source)
Source)
Caused by: java.lang.LinkageError: loading constraint violation: loader
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
... 24 more
(java.lang.NoClassDefFoundError:
org/eclipse/wst/xml/core/internal/contentmodel/CMDocument)
Source)
Source)
Source)
Source)
Caused by: java.lang.NoClassDefFoundError:
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
... 24 more
Re: Exception when using the JSF Facelets Tools Incubator [message #515720 is a reply to message #476138] Fri, 19 February 2010 17:20 Go to previous messageGo to next message
Raghu Srinivasan is currently offline Raghu Srinivasan
Please try the new build :
http://www.eclipse.org/downloads/download.php?file=/webtools /downloads/drops/R0.2/S-0.2-200906250000/wtp-incubator-jsf-f acelets-tools-0.2-20090625.zip
Sorry for the late response.
-Raghu
Raghu Srinivasan,
Project Lead - JSF
Re: Exception when using the JSF Facelets Tools Incubator [message #621229 is a reply to message #476138] Fri, 19 February 2010 17:20 Go to previous message
-Raghu
Raghu Srinivasan,
Project Lead - JSF
Raghu Srinivasan,
Project Lead - JSF
Previous Topic:XHTML Editor and JSF Custom Component and Namespace resolution problem
Next Topic:JSF 2.0 Facelets content assist not working
Current Time: Thu May 23 06:20:53 EDT 2013
Powered by FUDForum. Page generated in 0.01698 seconds
