Home » Eclipse Projects » Service Oriented Architecture Tools Platform (STP) » Reusing SCA Service Implementations
| Reusing SCA Service Implementations [message #620092] |
Wed, 01 October 2008 07:59  |
Originally posted by: michael.gebhart.googlemail.com
when using the SCA editor to create my service architecture, I can
easily implement services. I can write a java class and set it as the
implementation of a component.
My question is: Can I only use this implementation within a SCA runtime?
We have a typical application server running and don't wanna provide a
SCA runtime. But we'd like to use SCA for modeling the architecture.
Or do we have to manually adapt the implementation that it works within
a typical WS-compliant java application server?
Is the SCA way an alternative for the usual web service programming? Is
it still necessary to write the web services as we have done it before?
(Using JAX-WS etc.)
Greetings
Michael
| Re: Reusing SCA Service Implementations [message #620095 is a reply to message #620092] |
Wed, 01 October 2008 08:02   |
Originally posted by: atoulme.intalio.com
Michael,
anything SCA related should be posted to the SCa newsgroup, that I added
to the to: list of this message.
If your message is both relevant to STP and SCA, you can send a message
to both newsgroups.
I hope it helps.
Antoine
Michael Gebhart wrote:
> (Using JAX-WS etc.)
> Greetings
> Michael
| Re: Reusing SCA Service Implementations [message #620096 is a reply to message #620092] |
Wed, 01 October 2008 08:48   |
Mickael Istria Messages: 612 Registered: July 2009 Location: Grenoble, France |
Hi Michael, all
Michael Gebhart a écrit :
Yes, it is easy to design composites and write implementations for
components with SCA editor.
I think that the implementation you wrote does not depend on SCA
runtime, it only depends on SCA annotations (@Reference, @Property...),
but those annotation don't change your class logic, thus you can use
your classes out of SCA context (but you'll have to provide the jar
containing SCA references to resolve annotations).
But the question that comes to me ie "why don't you use a SCA runtime?".
I understand that there may be conflicts because with some
applications server, but it is worse trying...
I can't help you on this topic.
> (Using JAX-WS etc.)
SCA is an alternative for generic (Java-friendly) service programming. I
often use it to expose WebServices simply by creating a java component
that exposes its service through a binding.ws, and it works quite well
without brainstorming:
<composite ...>
<component name="myComponent">
<implementation.java class="package.ServiceImpl" />
<service name="myService">
<interface.java interface="package.IService" />
<binding.ws uri="http://localhost:8081/endpoint" />
</service>
</component>
</composite>
Then, you have a web service published on localhost:8081/endpoint, and
your SCA runtime made everything necessary to get it working, you simply
wrote the composite, the interface, and the implementation (only
business code)
> Greetings
> Michael
Mickael
| Re: Reusing SCA Service Implementations [message #620097 is a reply to message #620096] |
Wed, 01 October 2008 08:49   |
Oops,
I clicked "Reply" without checking the forum.
Sorry for the spam...
Mickael
Mickael Istria a écrit :
> Hi Michael, all
>> runtime? We have a typical application server running and don't wanna
>> provide a SCA runtime. But we'd like to use SCA for modeling the
>> architecture.
> I understand that there may be conflicts because with some applications
>> within a typical WS-compliant java application server?
>> Is it still necessary to write the web services as we have done it
>> before? (Using JAX-WS etc.)
> <composite ...>
> </service>
> </component>
> </composite>
> business code)
>> Greetings
>> Michael
> Mickael
| Re: Reusing SCA Service Implementations [message #620100 is a reply to message #620097] |
Wed, 01 October 2008 09:35  |
Stephane Drapeau Messages: 198 Registered: July 2009 |
Oops! Next time, I will use the refresh button before sending my message...
I agree with you Mickael.
Stéphane Drapeau
Obeo
> Oops,
> Mickael
>> Hi Michael, all
>>> Hi,
>>> architecture.
>> @Property...), but those annotation don't change your class logic,
>> thus you can use your classes out of SCA context (but you'll have to
>> provide the jar containing SCA references to resolve annotations).
>> runtime?". I understand that there may be conflicts because with some
>> I often use it to expose WebServices simply by creating a java
>> component that exposes its service through a binding.ws, and it works
>> quite well without brainstorming:
>> <composite ...>
>> </service>
>> </component>
>> </composite>
>> simply wrote the composite, the interface, and the implementation
>> (only business code)
>>> Greetings
>>> Michael
>> Regards,
>> Mickael
Current Time: Sat May 25 08:54:56 EDT 2013
Powered by FUDForum. Page generated in 0.07542 seconds
