Home » Eclipse Projects » Eclipse Communications Framework (ECF) » ECF 1.1 available
| ECF 1.1 available [message #619565] |
Sat, 08 September 2007 22:41  |
Scott Lewis Messages: 942 Registered: July 2009 |
Hi Folks,
ECF 1.1 now available at normal locations. See below for links.
The New and Noteworthy is not done yet, so committers please send any
additions to ecf-dev@eclipse.org i.e. if the placeholders that are there
have missed something that you feel the N&N should include.
Particularly noteworthy was the work of Google SOC 2007 student Moritz
Post on the Jingle VOIP protocol:
http://wiki.eclipse.org/VoIP_via_the_ECF_Call_API_and_the_Ji ngle_Protocol
ECF was also the beneficiary of some great contributions for the Eclipse
BugDay. Thanks to all who participated and the committers who
supported/reviewed.
See also the ECF OSU Open Source Lab site...for significant additions
for JMS-based communications: a new Websphere CE provider, as a new BEA
Weblogic-based JMS provider, and a JGroups (reliable multicast) based
provider. Along with JXTA, JGroups is a 'true' peer-to-peer provider.
It's not done yet, but is working. Further, all of these new providers
implement ECF datashare, the remote OSGI services API, and the ECF
shared object API.
Scott
Download and Update Site info: http://www.eclipse.org/ecf/downloads.php
New and Noteworthy: http://www.eclipse.org/ecf/NewAndNoteworthy.html
OSU OSL: http://ecf1.osuosl.org
CVS tag for release: v20070908-1720
| Re: ECF 1.1 available [message #619566 is a reply to message #619565] |
Sun, 09 September 2007 16:30   |
Bill Joy Messages: 60 Registered: July 2009 |
Member |
Scott, I took a look at the source code for the connection logic in the
JGroups implementation. I realize it is not done, but thought I would bring
up the following issues that I noticed.
One is that it uses the default stacks.xml file provided with JGroups to
define the protocol. A plugin should be able to provide its own protocol
definitions when initializing a JChannel.
Another issue is that the implementation seems only to support Eclipse
peers. I'd like to see an option so a plugin can create its own
PullPushAdapter to send/receive messages. Currently the JChannel is
not exposed which prevents accessing this API.
"Scott Lewis" <slewis@composent.com> wrote in message
news:46E35D3E.4020106@composent.com...
> Hi Folks,
> supported/reviewed.
> See also the ECF OSU Open Source Lab site...for significant additions for
> implement ECF datashare, the remote OSGI services API, and the ECF shared
> object API.
> Scott
| Re: ECF 1.1 available [message #619567 is a reply to message #619566] |
Sun, 09 September 2007 20:03   |
Hi Bill,
Thanks for the comments...just to let you know a couple of things we're
doing:
Very true. I'm working on a URI/ID spec for the ECF jgroups provider
that will allow custom protocol definitions along with using those in
stacks.xml. There doesn't seem to be an exiting URI spec for jgroups
currently...I'm thinking something like this:
jgroups:<stackname>://<mcastip>:<mcastport>/<channelName >&stackConfig=<config
url>
Where stackname (if omitted) has a default of 'udp', stackConfig has a
default of 'stacks.xml'.
I'm actually engaged in a dialog with Bela Ban about what a jgroups ID
syntax would be on the javagroups users/dev mailing list. I would be
very interested in your and other's thoughts about this:
https://lists.sourceforge.net/lists/listinfo/javagroups-user s
See the archive and please participate in discussion and I will
implement something that works.
Not sure I understand your request Bill.
I *think* that as long as the JChannel has access to the same stack
configuration/same channel name/and same low-level classes (i.e. those
in org.eclipse.ecf.provider.jgroups.connection...which are public), then
it should be able to connect to/send/receive messages on that
channel...even interact with Equinox-based (Eclipse is not required BTW).
The ECF provider should ignore messages which are not of a relevant
type...I haven't tested this yet, but if this doesn't work then I would
consider it a bug. I don't *think* it's necessary to expose the
JChannel instance directly. It would only be necessary if the
application wanted to use the ECF authentication and group membership
APIs...and at that point it pretty much becomes an IContainer.
In any event (so to speak), let me know if I'm misinterpreting your
desire or needs here.
BTW Bill...any chance that your company (Borland) could be convinced to
officially participate in ECF...especially given the recent directions
in Eclipse-based collaboration:
http://www.borland.com/us/company/news/press_releases/2005/0 5_31_05_borland_announces_jbuilder_product_roadmap.html
For example, we'd love to have a provider based upon Borland's
server/protocol for ECF...and even better would love to have Borland's
participation, support, and even perhaps contributions for ECF, Mylar
integration, etc.
Scott
>> Hi Folks,
>> supported/reviewed.
>> object API.
>> Thanks,
>> Scott
| Re: ECF 1.1 available [message #619568 is a reply to message #619567] |
Sun, 09 September 2007 22:40   |
Member |
Hi Scott, thanks for the response.
You might want to consider in your spec that JGroups also supports unicast
messages.
Regarding the request for access to JChannel, I have an legacy application
to maintain and not all peers are running on Eclipse. In that
implementation, "services" are registered with a peer manager and each has
its own unique string identifier and PullPushAdapter to send/receive
messages via the JChannel to/from the identical service running on other
peers.
It looks to me like the ECF implementation for this type of connection is
only intended to provide the equivalent of a single "service" (apparently
one that supports group chat). I need access to the JChannel to create an
PullPushAdapter instance for each of the legacy services.
Note that Borland/CodeGear has already made a contribution to Mylar (now
Mylyn) of an XPlanner connector and is also maintaining that codebase.
http://blogs.codegear.com/ravi/archive/2007/03/07/32778.aspx
http://jroller.com/eu/entry/xplanner_connector_for_mylyn
Regarding ECF participation, I'll send an email around again (this time we
are under CodeGear management) and see what comes up. I'll contact you
privately when I get some answers.
news:46E489BC.2010401@composent.com...
> Hi Bill,
> doing:
>> bring
> Very true. I'm working on a URI/ID spec for the ECF jgroups provider that
> url>
> syntax would be on the javagroups users/dev mailing list. I would be very
> See the archive and please participate in discussion and I will implement
> configuration/same channel name/and same low-level classes (i.e. those in
> org.eclipse.ecf.provider.jgroups.connection...which are public), then it
> should be able to connect to/send/receive messages on that channel...even
> consider it a bug. I don't *think* it's necessary to expose the JChannel
> instance directly. It would only be necessary if the application wanted
> to use the ECF authentication and group membership APIs...and at that
> In any event (so to speak), let me know if I'm misinterpreting your desire
> or needs here.
> officially participate in ECF...especially given the recent directions in
> integration, etc.
> Scott
>>> Hi Folks,
>>> supported/reviewed.
>>> for
>>> shared
>>> object API.
>>> Thanks,
>>> Scott
| Re: ECF 1.1 available [message #619569 is a reply to message #619568] |
Sun, 09 September 2007 23:06   |
Hi Bill,
> messages.
Yeah, I want the ID/URI spec to support any transport jgroups support.
Please anyone that has any comments/thoughts about the format of the
URI/ID participate in the discussion on the javagroups-users mailing list.
> peers.
I would be happy to expose a public accessor for the JChannel (in the
AbstractJGroupsConnection in the JGroupsClient/ManagerContainer. But of
course, your code will have to have knowledge of the type of IContainer
(JGroupsContainer) and cast to that type. Work for you?
BTW, you and others might be interested in the ECF 'remoteservices' API
for registering/finding and invoking (asynch or synch) OSGI services.
The API 'looks' a lot like the normal OSGi services API (i.e.
IRemoteServicesContainerAdapter vs. BundleContext, and
IRemoteServiceReference vs ServiceReference) and also includes both
proxy-based and message based remote invocation styles (see
IRemoteService interface). It's got javadocs here:
http://wiki.eclipse.org/ECF_API_Docs#Remote_Services_API
Note that ECF makes this API completely transport independent, and we
now have the following impls that support it:
ECF Generic (ecftcp)
Websphere CE/ActiveMQ JMS
Weblogic JMS
JGroups
XMPP
Also, it's small in code size, and supports CDC 1.0/Foundation 1.0 EEs.
There's also a test plugin that includes the remoteservices API
testing for jgroups provider in <ecf osuosl anon CVS
module>/tests/org.eclipse.ecf.tests.provider.jgroups.
I'm also persuing interating with the OSGI enterprise experts groups, as
a lot of thinking is now going on for remote OSGi, and I think ECF's
remoteservices API could provide some value for those efforts (e.g. real
transport independence).
Yeah I've seen that. It's one reason why I think it would be in
Borland's interests to support ECF as well :).
OK, thanks!
Scott
>> Hi Bill,
>> doing:
>>> bring
>> url>
>> or needs here.
>> integration, etc.
>> Thanks,
>> Scott
>>>> Hi Folks,
>>>> supported/reviewed.
>>>> for
>>>> shared
>>>> object API.
>>>> Thanks,
>>>> Scott
| Re: ECF 1.1 available [message #619572 is a reply to message #619571] |
Sun, 09 September 2007 23:52   |
Hi Bill,
Bill Joy wrote:
> I did not realize that class would be accessible to me. Maybe instead you
> could fill in the empty implementation for IAdaptable.getAdapter() so you
> don't have to add a new accessor?
Since the interface class that would be used for IAdaptable (call it
IChannelRetriever), would have to be declared in
org.eclipse.ecf.provider.jgroups (it wouldn't make sense to make it part
of one of the abstract ECF APIs)...it's probably easier to just leave it
as an accessor on JGroupsClient/ManagerContainer. Your code can just
have something that goes
if (container instanceof JGroupsClientContainer) {
// cast and go
Channel c = ((JGroupsClientContainer) container).getJChannel();
} else { //not JGroups
Rather than
IChannelRetriever cr = (IChannelRetriever)
container.getAdapter(IChannelRetriever.class);
if (cr != null) {
// call it
Channel c = cr.getJChannel();
In either case, a class (JGroupsClientContainer or IChannelRetriever)
has to be accessed in the org.eclipse.ecf.provider.jgroups plugin, and
therefore your code will have a direct (compile time) dependency on that
plugin. Which is undesirable for building clients that may run on other
IContainer types, but for a legacy client that uses JGroups already it
shouldn't be a problem.
Of course there's also the risk that the jgroups provider (or jgroups
itself) would be more likely to change and break such code...but you run
that risk with any jgroups-specific code anyway.
Scott
> news:46E4B797.2030805@composent.com...
>> Hi Bill,
>> Scott Lewis wrote:
>>> Hi Bill,
>> <stuff deleted>
>> I've implemented a 'getJChannel()' method on AbstractJGroupsConnection,
>> JGroupsClientContainer, and JGroupsManagerContainer. See the src on
>> ecf1.osuosl.org if you want to look at right away.
>> Scott
| Re: ECF 1.1 available [message #619578 is a reply to message #619566] |
Mon, 17 September 2007 01:55   |
Hi Bill,
Over the past few days, I've added a 'stackConfig' extension point to
the org.eclipse.ecf.provider.jgroups plugin. This ep allows plugins to
define a stack configuration file by pointing to a valid config file.
The stack config can then be referred to in the jgroups URI (e.g. if the
id in the stackConfig extension is org.foobar.mystackconfig):
jgroups:///channelName?stackName=myname&stackConfigID=or g.foobar.mystackconfig
Scott
>> Hi Folks,
>> supported/reviewed.
>> object API.
>> Thanks,
>> Scott
| Re: ECF 1.1 available [message #619597 is a reply to message #619565] |
Mon, 01 October 2007 16:14   |
Member |
Scott, I am trying to get my JMDNS implementation working on ECF 1.1 and
having problems. I see that build has been revoked for administrative
reasons but it was still present Friday on the Europa update site when our
integration team pulled it in.
After fixing some compile errors and new deprecation warnings due to 1.1
changes, I noticed that the JMDNS namespace name was changed so I updated
that.
Now I try my IDFactory.getDefault().createID(String, Object[]) and get an
exception thrown because the namespace name "ecf.namespace.jmdns" is not in
the hash table.
I dumped the hash table and see these entries (the ones that were not null):
ecf.xmpps=Namespace[name=ecf.xmpps;scheme=xmpps;description= ],
ecf.bittorrent=Namespace[name=ecf.bittorrent;scheme=torrent; description=],
ecfircid=Namespace[name=ecfircid;scheme=irc;description=],
org.eclipse.ecf.core.identity.StringID=Namespace[name=org.ec lipse.ecf.core.identity.StringID;scheme=org.eclipse.ecf.core .identity.StringID;description=],
org.eclipse.ecf.core.identity.LongID=Namespace[name=org.ecli pse.ecf.core.identity.LongID;scheme=class
org.eclipse.ecf.core.identity.LongID;description=],
ecf.xmpp=Namespace[name=ecf.xmpp;scheme=xmpp;description=],
xmpp.room.jive=Namespace[name=xmpp.room.jive;scheme=xmpp.muc ;description=],
org.eclipse.ecf.core.identity.GUID=Namespace[name=org.eclips e.ecf.core.identity.GUID;scheme=org.eclipse.ecf.core.identit y.GUID;description=],
ecf.msn.msnp=Namespace[name=ecf.msn.msnp;scheme=msn;descript ion=]
No JMDNS entry with either the old or new name. I looked at the jmdns
plugin and see
org.eclipse.ecf.provider.jmdns_1.0.500.v20070908-1720.jar
Why isn't the JMDNS plugin getting loaded? Is there some additional thing I
have to do now that I missed?
| Re: ECF 1.1 available [message #619598 is a reply to message #619597] |
Mon, 01 October 2007 18:14   |
Hi Bill,
> that.
> the hash table.
Hmmm. Very strange. I just installed a fresh copy of eclipse 3.4m2 and
then used the ECF europa update to install all of ECF from here:
http://download.eclipse.org/technology/ecf/europa-update
(this is the source of the ECF project update site contributions for
Europa).
Then in this new installation I created a new plugin project with deps
on org.eclipse.ecf, org.eclipse.ecf.discovery bundles and wrote this code:
try {
ID newID =
IDFactory.getDefault().createID(IDFactory.getDefault().getNa mespaceByName( "ecf.namespace.jmdns"),"_ecftcp._tcp.local.");
System.out.println("id="+newID);
System.out.println("namespaces="+IDFactory.getDefault().getNamespaces());
} catch (IDCreateException e) {
// TODO Auto-generated catch block
e.printStackTrace();
} catch (SecurityException e) {
And this works just fine i.e. when run produces console output:
id=ServiceID[type=_ecftcp._tcp.local.;name=null;full=_ecftcp ._tcp.local.]
namespaces=[Namespace[name=ecf.msn.msnp;scheme=msn;descripti on=],
Namespace[name=org.eclipse.ecf.core.identity.GUID;scheme=org .eclipse.ecf.core.identity.GUID;description=],
Namespace[name=xmpp.room.jive;scheme=xmpp.muc;description=],
Namespace[name=org.eclipse.ecf.core.identity.LongID;scheme=c lass
Namespace[name=ecf.namespace.jmdns;scheme=jmdns;description= ],
Namespace[name=org.eclipse.ecf.core.identity.StringID;scheme =org.eclipse.ecf.core.identity.StringID;description=],
Namespace[name=ecf.provider.filetransfer;scheme=ecf.provider .filetransfer;description=],
Namespace[name=ecf.bittorrent;scheme=torrent;description=],
Namespace[name=ecf.xmpps;scheme=xmpps;description=]]
> plugin and see
I also see the plugin in the Eclipse plugin list (i.e. Help->About
Eclipse SDK->Plugin Details. Is this where you are seeing it also?
Perhaps you could also look at the console try to see what state the
jmdns provider plugin is in there (i.e. resolved, installed, etc).
I don't think so...I'm currently puzzled (since I can't reproduce).
Is it possible that you have a conflicting/more recent version of the
jmdns plugin in your workspace?
Please let me know, and we'll figure out.
BTW, there are additional discovery API additions and changes coming
(not large ones, but significant). See following bugs for info or to
comment/critique (please!):
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204423
https://bugs.eclipse.org/bugs/show_bug.cgi?id=200804
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204433
Scott
| Re: ECF 1.1 available [message #619600 is a reply to message #619598] |
Tue, 02 October 2007 10:46   |
Member |
I am running an Eclipse 3.3 refreshed from the Europa site.
The ECF plugins including JMDNS appear in Help | About | Plug-in Details
with no indications of problems. I don't see any pertinent errors or
warnings in the error log.
As an experiment I tried adding the following code to my plugin:
JMDNSNamespace namespace = new JMDNSNamespace();
namespace.initialize("ecf.namespace.jmdns", "jmdns");
IDFactory.getDefault().addNamespace(namespace);
and this did get around the namespace problem. However there was
an NPE in a thread running JmDNS.SocketListener and I was unable to start
a session with an older version of Eclipse.
Exception in thread "JmDNS.SocketListener" java.lang.NullPointerException
at javax.jmdns.JmDNS.incrementName(JmDNS.java:819)
at javax.jmdns.DNSRecord$Service.handleQuery(DNSRecord.java:609 )
at javax.jmdns.JmDNS.handleQuery(JmDNS.java:1034)
at javax.jmdns.JmDNS.access$4(JmDNS.java:1019)
at javax.jmdns.JmDNS$SocketListener.run(JmDNS.java:1146)
at java.lang.Thread.run(Thread.java:595)
news:4701713D.3050008@composent.com...
> Hi Bill,
>> our integration team pulled it in.
>> updated that.
>> in the hash table.
> Europa).
> Then in this new installation I created a new plugin project with deps on
> try {
> ID newID =
>> null):
>> plugin and see
> I also see the plugin in the Eclipse plugin list (i.e. Help->About Eclipse
> Perhaps you could also look at the console try to see what state the jmdns
>> thing I have to do now that I missed?
> BTW, there are additional discovery API additions and changes coming (not
> Scott
| Re: ECF 1.1 available [message #619601 is a reply to message #619600] |
Tue, 02 October 2007 11:17   |
Hi Bill,
This is (unfortunately) mystifying for me, as I can't seem to reproduce.
Do you have an old (or any other) version of ECF installed in Eclipse?
Any ECF plugins in your workspace?
Could you start eclipse with the console ( -console on command line) and
in the console check the state of all plugins with
osgi> ss
<produces lots of output>
osgi> bundle org.eclipse.ecf.provider.jmdns
osgi> headers org.eclipse.ecf.provider.jmdns
<produces headers for that bundle>
osgi> status org.eclipse.ecf.provider.jmdns
<produces status info for that bundle>
Also if you could run your test code and then give the console commands
above as well that might tell us something to go on.
Scott
>> Hi Bill,
>>> updated that.
>>> in the hash table.
>> Europa).
>> try {
>> ID newID =
>>> null):
>>> plugin and see
>> Scott
| Re: ECF 1.1 available [message #619602 is a reply to message #619601] |
Tue, 02 October 2007 12:22  |
Member |
I sent this output to you directly.
news:47026124.1010400@composent.com...
> Hi Bill,
> osgi> ss
> Scott
>>> Hi Bill,
>>>> and
>>>> 1.1
>>>> updated that.
>>>> an
>>>> not
>>>> in the hash table.
>>> Europa).
>>> on
>>> try {
>>> ID newID =
>>>> null):
>>>> plugin and see
>>> Eclipse
>>> jmdns
>>> (not
>>> Scott
Current Time: Mon May 20 12:13:29 EDT 2013
Powered by FUDForum. Page generated in 0.02269 seconds
