Home » Eclipse Projects » Eclipse Communications Framework (ECF) » Package visibility issues
Package visibility issues [message #619586] Mon, 24 September 2007 19:26 Go to next message
Scott Dybiec is currently offline Scott Dybiec
Member
Ran into a couple plug-in package visibility issues. I'm using ECF 1.0.2.
I imported the source for the sample applications in
org.eclipse.ecf.example.collab_1.0.2 into my workspace. I assume these
examples are designed to be a starting point for developers to learn the
API. All went well, except that ECFGenericHyperlink.java gives this error:
Access restriction: The type AbstractURLHyperlink is not accessible due
to restriction
on required library
C:\projects\regatta-workbench\eclipse-3.3\eclipse\plugins
\org.eclipse.ecf.ui_1.0.200.v20070805-1626.jar
and ECFGenericHyperlinkDetector.java gives a similar compile error.
Also, I imported the RCP XMPP chat application from CVS and found that
org.eclipse.ecf.ui.actions.AsynchContainerConnectAction had a similar
visibility issue.
None of these look like classes intended to be internal to ECF.
Will there be a 1.0.3?
$cott
Re: Package visibility issues [message #619587 is a reply to message #619586] Mon, 24 September 2007 22:56 Go to previous message
Scott Lewis is currently offline Scott Lewis
Hi Scott,
> API.
No, we're not really there yet, unfortunately. We've got a bug in place
to refactor/redo the org.eclipse.ecf.example.collab plugin
https://bugs.eclipse.org/bugs/show_bug.cgi?id=160633
I've reopened this bug so that it can be used to capture these issues.
> to restriction
> on required library
Hmmm...I don't immediately understand why this is giving you an access
restriction warning (it doesn't in my workspace), as the
AbstractURLHyperlink class (and AbstractURLHyperlinkDetector) are in an
exported package in org.eclipse.ecf.ui.
> visibility issue.
We/I haven't been maintaining the RCP XMPP chat application (I assume
you mean the one from ecf1.osuosl.org). But I don't seem to have
visibility issues for dependencies.
I'm not sure why this would be necessary, but perhaps if you imported
the ECF core projects directly into your workspace (instead of having
them in the target platform).
I think yes. But it probably won't contain any changes that occur over
the next few days (it will probably be constructed for the Europa
maintenance release to happen this Friday).
There will also be a 1.1 (or perhaps it will be called 1.2) after we
have a foundation release review.
Scott
Previous Topic:muc with xmpp
Next Topic:ecf skype
Current Time: Sat May 25 18:08:13 EDT 2013
Powered by FUDForum. Page generated in 0.03427 seconds
