Home » Modeling » Modeling (top-level project) » Sequence Diagram with Eclipse
Sequence Diagram with Eclipse [message #619442] Thu, 04 March 2010 01:58 Go to next message
No real name is currently offline No real name
We have created a tool for Reverse Engineering any Java application, which creates dynamic UML Sequence Diagrams and Class Diagrams.
All you have to do is just run your application and sit back. Reverse Java runs in background tracing all the activities happening inside your application and creates UML diagram for you. You can get more details at
http://www.reversejava.com
I would like to enhance the capability of the tool by integrating it with Eclipse, where by users after viewing the Sequence diagram can also edit it.
Can some please recommend me any APIs which I can use for this?
Thanks and Regards,
Rajesh Jadhav.
Re: Sequence Diagram with Eclipse [message #619443 is a reply to message #619442] Thu, 04 March 2010 05:12 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
--------------080208010406050804070106
Content-Type: text/plain; charset=UTF-8; format=flowed
Rajesh,
What APIs are you using now to build the sequence and class diagrams?
At Eclipse you'd be using the UML2
<http://www.eclipse.org/modeling/mdt/?project=uml2> project's APIs.
Aren't class diagrams more of a static thing you'd produce from
analyzing the Java source?
> details at
> also edit it.
> Thanks and Regards,
> Rajesh Jadhav.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Rajesh,<br>
<br>
At Eclipse you'd be using the <a
href="http://www.eclipse.org/modeling/mdt/?project=uml2">UML2</a>
project's APIs.  Aren't class diagrams more of a static thing you'd
produce from analyzing the Java source?  <br>
<br>
<br>
<a class="moz-txt-link-abbreviated" href="mailto:rsjadhav26@gmail.com">rsjadhav26@gmail.com</a> wrote:
<blockquote cite="mid:hmnlmo$85d$1@build.eclipse.org" type="cite">We
<br>
details at <br>
<a class="moz-txt-link-freetext" href="http://www.reversejava.com">http://www.reversejava.com</a>
<br>
<br>
<br>
also edit it.
<br>
<br>
<br>
<br>
Thanks and Regards,
<br>
Rajesh Jadhav.
<br>
<br>
</blockquote>
</body>
</html>
--------------080208010406050804070106--
Re: Sequence Diagram with Eclipse [message #619484 is a reply to message #619443] Tue, 09 March 2010 04:32 Go to previous message
Thanks for your Reply.
Currently we are using Java 2D to draw class diagrams and sequence diagrams.
Thanks and Regards,
Rajesh
Previous Topic:Problem installing DSL Toolkit
Next Topic:Sequence Diagram with Eclipse
Current Time: Mon May 20 00:52:21 EDT 2013
Powered by FUDForum. Page generated in 0.01634 seconds
