Home » Eclipse Projects » Eclipse Communications Framework (ECF) » Can't login to: ##wicket@irc.freenode.net
Can't login to: ##wicket@irc.freenode.net [message #618793] Fri, 06 July 2007 11:31 Go to next message
Martin Funk is currently offline Martin Funk
just got aware of the irc client within ecf.
Even though I'm able to log into
#papernapkin@irc.freenode.net
I don't seem to be able to log into:
For some reason it seems to be importent to have the two # in front of the
group name.
See: http://incubator.apache.org/wicket/community.html#Community- irc
Any hints?
Martin
Re: Can't login to: ##wicket@irc.freenode.net [message #618795 is a reply to message #618793] Fri, 06 July 2007 14:46 Go to previous messageGo to next message
Scott Lewis is currently offline Scott Lewis
Hi Martin,
ECF currently uses URL syntax for connecting to IRC channels, and URL
syntax uses '#' as a delimiter (between path and fragment)...so this
makes it problematic to have two '#' characters in the channel name for
the connnect dialog.
Note that the syntax for ECF IRC is:
<username>@<host>[/<channel>[,channel]]
So it's not the group name prior to the '@irc.freenode.net', but rather
your desired login name. For your first URL this would be:
martin@irc.freenode.net/#papernapkin (or whatever your desired
username is other than 'martin')
OR
martin@irc.freenode.net/papernapkin
But unfortunately this will not currently work:
martin@irc.freenode.net/##wicket
Because of the URL syntax issue.
A workaround, however, is to simply log into
And once you are logged in you can type:
/join ##wicket
And you will join the ##wicket channel.
I've filed the following bug to address the need to support channel
names of the form '##name' in the connect dialog:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195690
Scott
Martin Funk wrote:
> group name.
> Any hints?
> Martin
Re: Can't login to: ##wicket@irc.freenode.net [message #618817 is a reply to message #618795] Sat, 07 July 2007 15:09 Go to previous message
Hi Scott,
> /join ##wicket
that's an idea, I should have gotten myself.
Thanks for the tip, it does work,
Martin
Previous Topic:FYI: open social networking
Next Topic:General Tips
Current Time: Sat May 18 01:30:10 EDT 2013
Powered by FUDForum. Page generated in 0.02186 seconds
