Home » Eclipse Projects » Service Oriented Architecture Tools Platform (STP) » About BPMN'layout
About BPMN'layout [message #616693] Tue, 12 August 2008 00:42 Go to next message
Stephen is currently offline Stephen
Member
I'm studying the source of BPMN. I want to modify the layout of
diagram to vertical as which horizontal originally.
Following, I found that it is not via set layout in the
diagram'editpart to constraint the pool but install a layout policy
which named BpmnDiagramXYLayoutE , Then, I try to modify it. Finally, I
make the layout vertical, however the width of the margin which figures
to the pool contains it, is still as before. The problem has been
puzzling me for three days! Anyone can help me to solve it.
Thank you very much!
Stephen
Re: About BPMN'layout [message #616694 is a reply to message #616693] Tue, 12 August 2008 02:12 Go to previous messageGo to next message
Eclipse User
Originally posted by: atoulme.intalio.com
Hi Stephen,
it'd be great if you could contribute this back to BPMN. I think a
vertical layout has been requested before.
You should edit those edit policies:
BpmnDiagramXYLayoutEditPolicy
PoolPoolCompartmentXYLayoutEditPolicy
I am not sure I understand the specific problem you mention. If you are
still facing it, please attach an image.
Antoine
Stephen wrote:
> Stephen
Re: About BPMN'layout [message #616695 is a reply to message #616694] Tue, 12 August 2008 21:57 Go to previous messageGo to next message
Member
--------------080209060505070704070401
Antoine Toulme wrote:
> Hi Stephen,
> Antoine
> Stephen wrote:
>> I make the layout vertical, however the width of the margin which
>> figures to the pool contains it, is still as before. The problem has
>> been puzzling me for three days! Anyone can help me to solve it.
>> Stephen
> Hi Stephen,
are still facing it, please attach an image.
> Antoine
> Stephen wrote:
>> Stephen
Hi, Antoine
Although the problem had been solved, I am deeply grateful for your
help. I found the key was in the PoolPoolCompartmentXYLayoutEditPolicy
yesterday and finally I had achieved my objective. However, I find a new
problem that the pool name is under the line of the pool compartment
when the layout is changed to vertical. How can I reverse them? Waiting
for your help.
thank you very much!
Stephen
Content-Type: image/bmp;
name="line.bmp"
Content-Disposition: inline;
filename="line.bmp"
Qk0mMwQAAAAAADYAAAAoAAAA0wEAAMQAAAABABgAAAAAAPAyBAAAAAAAAAAA AAAAAAAAAAAA
mais87qZ87qZ//////////////////////////////////////////////// ////////////
////qamp/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+joqamp//////////////////////////////////////// ////////////
////////////////////////////////////////////////////5e3u7PHz 7PH07vP07/T1
8PX28/f39Pj59/n5+Pv7+fv7+fv7+v39+/7++/7++/7+5e3u////2Ons2Ons 2Ons2OnsAAAA
/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo5dDQvaysuaiouaiouaiouaio uaiouaiouaio
uaiouaiouaiouaiouaiouaiouaiouaiouaiouaiouaiouaiouaiouaiouaio uaiouaiouaio
uaiouaiouaiouaiou6qq3srK/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo69bWuaiouaiouaiouaiouaiouaio uaiouaiouaio
uaiouaiouaiouaiouaiouaio3srK/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+joyri4uaiouaiouaiouaiouaiouaio uaiouaiouaio
uaiouaiouaiouaiouaiouaiowK+v/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+jo/+jo/+jo/+nph4GBEA8PAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
EBAQY2FhsaKiuaiouaiouaiouaio/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+jo/+jo/+npSEdHeHh47+/v//////////////////////// ////////////
7+/vj4+PNjY2t6iouaiouaiouaio/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+jo/+jol5CQaGho//////////////////////////////// ////////////
////////j4+PYl9fuaiouaiouaio/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+jo/+joODc3x8fH//////////////////////////////// ////////////
////////39/fHx8fuaiouaiouaio/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+jo/+joCAgI9/f3//////////////////////////////// ////////////
////////////AAAAuaiouaiouaio/+jo/+jo/+jo/+jo/+jo/+jo/+jo/+jo /+jo/+jo/+jo
/+jo/+jo/+jo/+jo/+joAAAA//////////////////////////////////// ////////////
Re: About BPMN'layout [message #616696 is a reply to message #616695] Wed, 13 August 2008 06:30 Go to previous messageGo to next message
Eclipse User
Take a look at PoolPoolCompartmentFigure.
Let me know how it goes!
Antoine
Re: About BPMN'layout [message #618461 is a reply to message #616696] Fri, 15 August 2008 02:21 Go to previous message
Member
> Antoine
Hi Antoine,
I am so sorry to bother you again. I have looked at
PoolPoolCompartmentFigure and found that its primary responsibility
is not to draw itself but to the lane figure in it. Then, I focus on its
editpart PoolPoolCompartmentEditPart and I find the code below:
FixedOneLineBorder border = new FixedOneLineBorder(
POOLCOMPARTMENTFIGURE_BORDER, 1, PositionConstants.TOP);
I modify orientation of the line to horizontal. But I can't make the
pool name above the line yet. Could you give me more hint.
Stephen
Previous Topic:Re: EContentAdapter behavior
Next Topic:Re: About BPMN'layout
Current Time: Wed May 22 11:42:51 EDT 2013
Powered by FUDForum. Page generated in 0.02814 seconds
