Home » Modeling » GMT (Generative Modeling Technologies) » [Epsilon] Problems using HUTN with UML metamodel
[Epsilon] Problems using HUTN with UML metamodel [message #618110] Tue, 01 July 2008 03:58
Pau Giner is currently offline Pau Giner
I've experienced problems with HUTN when trying to define a UML model.
The problem I guess is that UML metamodel uses its own dataTypes. So
HUTN cannot convert strings to the UML-defined String datatype.
For example, if I define the following:
@Spec {
MetaModel "uml" {
nsUri = "http://www.eclipse.org/uml2/2.1.0/UML"
Packages {
Package "Pk" {
nestedPackage: Profile "Pr" { name: "profile" }
ownedType: Class "C" { name: "class" }
I get the following error:
[Line: 9, Column: 5, Reason: Expected String for: name, Line: 10,
Column: 35, Reason: Expected String for: name, Line: 11, Column: 28,
Reason: Expected String for: name]
Is there any construct to handle the creation of these datatypes?
--Pau
Previous Topic:[MOFScript] loading Metamodel
Next Topic:[AM3] Emfatic zoo
Current Time: Fri May 24 03:28:53 EDT 2013
Powered by FUDForum. Page generated in 0.01657 seconds
