| Asking jsf semantics validator for ISymbol created from jsf tag attribute [message #617501] |
Fri, 14 March 2008 08:42 |
Vadim Dmitriev Messages: 73 Registered: July 2009 |
Member |
Hi.
Is there a way to request wtp.jsf framework from some ContextSymbolFactory
for a result of symbol resolution process for a specific JSP tag attribute?
Just thought that there are cases when ISymbol for/from some attribute
created by ContextSymbolFactory can be reused by other factories/attribute
types.
For example, tr:table. Its 'var' attribute symbol can be re-used for
'current' property of 'varStatus' and 'sortProperty' of every nested
tr:column (and maybe somewhere else). Validation/symbol creation for every
of these attributes requires almost identical information to be calculated
multiple times. It will speed up validation a little if there is a
possibility just to ask jsp semantics validator for a symbol (if any) of
some jsp tag attribute.
And if there is none, is there a way to create listener for some 'JSP
semantics validation started' event?
Thanks!
FUDForum. Page generated in 0.01495 seconds
