| JEM 2.0.0 [message #616218] |
Sun, 08 July 2007 14:43 |
Chris Messages: 97 Registered: July 2009 |
Member |
I really want to use VE for a simple at-home project and I've been having a
devil of a time trying to find the right combination of component versions
to make it work. I caught Erik's post of his fix to make it work with
Europa (many thanks to Erik) and I'm on that path right now. I've been
through 2 or 3 iterations of upgrading or finding require plug-ins, but I'm
currently stuck on
Requested operation cannot be performed because it would invalidate the
current configuration. See details for more information.
Visual Editor (1.3.0.200707070308) requires plug-in "org.eclipse.jem
(2.0.0)", or compatible.
when trying to enable VE. Where can I find org.eclipse.jem (2.0.0)?
Haven't been able to find it via web links off of the Eclipse site or
through Find and Install in Europa.
Is there a jar that can be dropped into plug-ins dir? If so, does it need
to be in a particular subdir?
-Chris
FUDForum. Page generated in 0.02297 seconds
