Home » Eclipse Projects » Service Oriented Architecture Tools Platform (STP) » How to eliminate BPMN diagram bubble assistant ?
How to eliminate BPMN diagram bubble assistant ? [message #614298] Mon, 21 April 2008 11:06 Go to next message
bacha  is currently offline bacha
Member
Hello ,
I'm developping a BPMN modeler using stp project source code.
I would like to eliminate the bubble assistant from editor and not allow
it to appear to user.
Could you please indicate to me how to do that ?
Thanks.
Firas
Re: How to eliminate BPMN diagram bubble assistant ? [message #614306 is a reply to message #614298] Mon, 21 April 2008 11:20 Go to previous messageGo to next message
Eclipse User
Originally posted by: atoulme.intalio.com
you can disable this setting by unchecking the "Show popup bars" option
in the BPMN diagrams page. You can do that programmatically by changing
the preference field being returned in the
PopupBarEditPolicyEx#getPreferenceName method.
Antoine
firas wrote:
> Hello ,
> Thanks.
> Firas
Re: How to eliminate BPMN diagram bubble assistant ? [message #614443 is a reply to message #614306] Tue, 22 April 2008 08:02 Go to previous message
Member
Thank you Mr Antoine for your help.
I did what you tell me to do and the result was nice.
Thanks.
Firas.
Previous Topic:STP Drivers
Next Topic:Can I use regular expression in B2J when runs BPEL
Current Time: Wed May 22 12:46:36 EDT 2013
Powered by FUDForum. Page generated in 0.01727 seconds
