| RCP with stp bpmn editor [message #614281] |
Tue, 15 April 2008 16:41 |
Originally posted by: fleabetto.libero.it
Hi everybody,
I'm new to the eclipse platform and i'm trying to make an rcp bpmn
editor with the Soa Tools Platform bpmn diagram editor.
My problem is, when i use the file -> "open file.." action to open a
"bpmn_diagram" file in the rcp workspace, the editor opens successfully
but if i try to open it programmatically with:
IFileStore store = EFS.getLocalFileSystem().getStore(file.getLocationURI());
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
IDE.openEditorOnFileStore(page, store);
or even with:
OpenLocalFileAction a = new OpenLocalFileAction();
a.init(PlatformUI.getWorkbench().getActiveWorkbenchWindow()) ;
a.run();
and browsing the same file in the rcp workspace, the editor crashes with
the following error in the log file:
!ENTRY org.eclipse.ui 4 0 2008-04-15 12:33:05.784
!MESSAGE Unable to create editor ID
org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditorID:
org.eclipse.core.runtime.CoreException: ERROR
!STACK 1
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1458)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2739)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1090)
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:105)
at kbel2.NavigationView.openBPMNdiagramOnTree(NavigationView.ja va:872)
at kbel2.NavigationView$1.run(NavigationView.java:406)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:443)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at kbel2.Application.start(Application.java:20)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
!SUBENTRY 1 org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1
!MESSAGE ERROR
The same error occurs when i try to open with the "open file.." action a
bpmn_diagram file which is not in the workspace.
Sometimes in the eclipse console appears also this error, even when i
use the "open file..." action, but the editor opens anyway.
org.eclipse.core.runtime.CoreException: Problems encountered while
setting project description.
org.eclipse.core.internal.resources.Project.setDescription(P roject.java:983)
org.eclipse.core.internal.resources.Project.setDescription(P roject.java:1009)
org.eclipse.stp.bpmn.diagram.part.BpmnCreationWizardPage.set upBpmnValidationBuildableNature(BpmnCreationWizardPage.java: 140)
org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditor.setupBpm nValidationBuildAbleNature(BpmnDiagramEditor.java:85)
org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditor.setDocum entProvider(BpmnDiagramEditor.java:73)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.updateDocumentProvider(DiagramDocumentEd itor.java:359)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSetInput(DiagramDocumentEditor.java:41 4)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.setInput(DiagramDocumentEditor.java:389)
org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:318)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init( DiagramEditor.java:641)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:116)
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
Thanks to all in advance.
Andrea
FUDForum. Page generated in 0.08601 seconds
