Home » Eclipse Projects » Eclipse Communications Framework (ECF) » supported protocols
| supported protocols [message #604018] |
Mon, 12 June 2006 12:52  |
Eugene Kuleshov Messages: 505 Registered: July 2009 |
I wonder what are the protocols used by public IM networks officially
supported by ECF? I see Jabber and I also saw Chris's article about
Yahoo (which is by the way not linked from ECF web site). But how about
ICQ, AOL and MSN?
regards,
Eugene
| Re: can't get shared editing working [message #605126 is a reply to message #605120] |
Sun, 25 June 2006 09:01   |
Jakub Kahovec Messages: 13 Registered: July 2009 |
Junior Member |
Thank you Ken for your suggestions,
1.
I'm quite sure that both Eclipse sessions have the ECF server
information as when I connect the project on both of them, I can chat
between them and if I open a shared editor (in the context menu in the
Navigator view, ECF->Open Shared Editor) in one session I receive a
message on the other and saying to that shared editor was open whether I
wish to open it too. When I open it and make some changes in it though I
can't those changes in the second session. I'm also a bit confused about
the difference between ECF->Open Shared Editor and Teams->Initiate
Shared Editor (in any case neither of them allow me to share changes).
2.
I can see trace information from the server console, there are something
like this:
(trace)connection[06/25/06;13:55:14:569]StringID[ecftcp://localhost:3282/server]
:3282:localhost:2707;send(AsynchMessage[[B@2f356f])
:3282:localhost:2699;send(AsynchMessage[[B@137d4a4])
(trace)container[06/25/06;13:55:14:579]processAsynch(org.ecl ipse.ecf.core.comm.A
synchConnectionEvent@fa39d7):StringID[ecftcp://localhost:3282/server]
(trace)container[06/25/06;13:55:14:579]handleSharedObjectMes sage:ContainerMessag
e[GUID[Rg._Z_GY5pq10.97uuJ.tMrs_Sk-];null;19;SharedObjectMes sage[StringID[chat];
[B@1eb904d]]:StringID[ecftcp://localhost:3282/server]
(trace)connection[06/25/06;13:55:14:579]StringID[ecftcp://localhost:3282/server]
:3282:localhost:2709;queueObject(GUID[1BewYIqTZc8Fbi4SXuGPow KBWvw-],[B@144b18f)
:3282:localhost:2710;queueObject(GUID[4Yf6eJiXMXjkvBu8ZA2aFZ JBO7Y-],[B@132ae7)
:3282:localhost:2708;queueObject(GUID[LHOY0mwiX8.DyBECrRFg2e oN8r8-],[B@1dfd868)
:3282:localhost:2708;send(AsynchMessage[[B@1dfd868])
:3282:localhost:2705;queueObject(GUID[ZDkOdwQCZdn7PGuvNw7Bk5 lEepU-],[B@1e6e305)
:3282:localhost:2709;send(AsynchMessage[[B@144b18f])
:3282:localhost:2710;send(AsynchMessage[[B@132ae7])
(trace)connection[06/25/06;13:55:14:589]StringID[ecftcp://localhost:3282/server]
3. I haven't tried neither the whiteboard app nor any other
datashare-based app so far.
Jakub
Ken Gilmer wrote:
> Hi Jakub,
> Looks like maybe either Eclipse session is not connected to your ECF
> datashare server. Here are some things to check:
> 1. Do both Eclipse sessions have the same ECF server information in
> preferences?
> 2. Do you see trace information from the server console when connecting
> either client?
> 3. Are you able to use other datashare-based apps such as the whiteboard
> example?
> Thanks
> Ken
> Jakub Kahovec wrote:
>> Hello,
>> I'm using Eclipse 3.1.2 and ECF plugin 0.8.6 and I can't get shared
>> editing working. I was carefully following the tutorial how to share
>> an editor so that on is typing and the other can see changing.
>> Everything works fine until I get to the point of creating a new
>> Shared Editor Session. When I open the dialog Shared Editro I can't
>> neither see nor choose Shared file, even though I connected the
>> project before and also
>> initiated shared editor.
>> Any idea what I'm doing wrong ?
>> Thank you very much.
>> Jakub
| Re: can't get shared editing working [message #605129 is a reply to message #605126] |
Sun, 25 June 2006 09:19   |
Junior Member |
3. So I've tried ScribbleShare and it works. When I draw into the one
session I can see it in the other.
> 1.
> 2.
> like this:
> Jakub
> Ken Gilmer wrote:
>> Hi Jakub,
>> preferences?
>> connecting either client?
>> whiteboard example?
>> Thanks
>> Ken
>>> Hello,
>>> Jakub
| Re: can't get shared editing working [message #605154 is a reply to message #605126] |
Tue, 27 June 2006 11:12   |
Ken Gilmer Messages: 17 Registered: July 2009 |
Junior Member |
Hi Jakub,
> 1.
The shared editor functionality I worked on is not connected to the ECF
context menu. To initiate a shared editing session, context menu:
team->initiate shared session. For a second client to connect, you need
to go file menu: new->team->shared editor session. From there you
should see the file shared from the original client. None of the
functionality is present in the ECF menu. I think this is something
Scott did before I was involved with ECF.
So, it seems like you're getting communication to the ECF server from a
client. If you follow these steps
( http://wiki.eclipse.org/index.php/Example_Shared_Text_Editor) do you
get any exceptions in the eclipse error log or in the ECF server trace?
> 2.
> like this:
> Jakub
> Ken Gilmer wrote:
>> Hi Jakub,
>> preferences?
>> whiteboard example?
>> Thanks
>> Ken
>>> Hello,
>>> Jakub
| Re: can't get shared editing working [message #605225 is a reply to message #605154] |
Tue, 27 June 2006 11:46   |
Junior Member |
--------------080908050503030906040607
Hi Ken,
Ken Gilmer wrote:
> Hi Jakub,
>> 1.
There is no exception related to ECF plugin in the Eclipse's error log.
And the ECF server's log (enclosed in the attachment) looks like there
is no problem either. But still, when I open File->New->Team->Shared
Editor Sesssion I can't see any files opened for sharing there.
>> I can't those changes in the second session. I'm also a bit confused
>> about
>> 2.
>> something like this:
>> Jakub
>> Ken Gilmer wrote:
>>> Hi Jakub,
>>> ECF datashare server. Here are some things to check:
>>> preferences?
>>> whiteboard example?
>>> Thanks
>>> Ken
>>>> Hello,
>>>> Jakub
name="error.log"
Content-Disposition: inline;
filename="error.log"
C:\eclipse\features\org.eclipse.ecf.serverfeature_0.8.6\bin>echo off
"Starting server with options: -Dorg.eclipse.ecf.Trace -Dorg.eclipse.ecf.provider.Trace and args: -c ..\conf\server.xml "
Creating server group named localhost to listen on port 3282
Creating container with id=ecftcp://localhost:3282/server, group=/server keepAlive=30000
(trace)idfactory[06/27/06;16:32:56:051]createID(Namespace[na me=org.eclipse.ecf.core.identity.StringID;scheme=org.eclipse .ecf.core.identity.StringID;description=],java.lang.String,ecftcp://localhost:3282/server)
(trace)gmm[06/27/06;16:32:56:402]addMember(StringID[ecftcp://localhost:3282/server]):StringID[ecftcp://localhost:3282/server]
(trace)gmm[06/27/06;16:32:56:402]<init>:StringID[ecftcp://localhost:3282/server]
(trace)container[06/27/06;16:32:56:482]<init>:StringID[ecftcp://localhost:3282/server]
Putting server localhost on the air
(trace)connection[06/27/06;16:32:56:482]group at port 3282 on the air
<ctrl>-c to stop server
(trace)connection[06/27/06;16:35:03:475]accept:/127.0.0.1
(trace)connection[06/27/06;16:35:03:605]serverrecv:ConnectRe questMessage[ecftcp://localhost:3282/server ;ContainerMessage[GUID[uiPQFsOLrfSqtKRztrjiZir7wns-];StringI D[ecftcp://localhost:3282/server];0;JoinGroupMessage[null]]]
(trace)connection[06/27/06;16:35:03:605]found container:ecftcp://localhost:3282/server for target ecftcp://localhost:3282/server
(trace)connection[06/27/06;16:35:03:635]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;setupThreads()
(trace)container[06/27/06;16:35:03:645]acceptNewClient(Socke t[addr=localhost/127.0.0.1,port=4362,localport=3282],/server ,ContainerMessage[GUID[uiPQFsOLrfSqtKRztrjiZir7wns-];StringI D[ecftcp://localhost:3282/server];0;JoinGroupMessage[null]],org.eclipse.ecf.provider.comm.tcp.Client@8ed465):StringID[ecftcp://localhost:3282/server]
(trace)container[06/27/06;16:35:03:645]addNewRemoteMember:GU ID[uiPQFsOLrfSqtKRztrjiZir7wns-]:StringID[ecftcp://localhost:3282/server]
(trace)gmm[06/27/06;16:35:03:645]addMember(GUID[uiPQFsOLrfSq tKRztrjiZir7wns-]):StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:35:03:655]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;start()
(trace)connection[06/27/06;16:35:03:655]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;setupPing()
(trace)connection[06/27/06;16:35:03:775]accept:/127.0.0.1
(trace)connection[06/27/06;16:35:03:785]serverrecv:ConnectRe questMessage[ecftcp://localhost:3282/server ;ContainerMessage[GUID[lRX5wIWN5OQ4UZy7Sbpwst8T6TE-];StringI D[ecftcp://localhost:3282/server];0;JoinGroupMessage[null]]]
(trace)connection[06/27/06;16:35:03:785]found container:ecftcp://localhost:3282/server for target ecftcp://localhost:3282/server
(trace)connection[06/27/06;16:35:03:785]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;setupThreads()
(trace)container[06/27/06;16:35:03:785]acceptNewClient(Socke t[addr=localhost/127.0.0.1,port=4363,localport=3282],/server ,ContainerMessage[GUID[lRX5wIWN5OQ4UZy7Sbpwst8T6TE-];StringI D[ecftcp://localhost:3282/server];0;JoinGroupMessage[null]],org.eclipse.ecf.provider.comm.tcp.Client@1e63e3d):StringID[ecftcp://localhost:3282/server]
(trace)container[06/27/06;16:35:03:785]addNewRemoteMember:GU ID[lRX5wIWN5OQ4UZy7Sbpwst8T6TE-]:StringID[ecftcp://localhost:3282/server]
(trace)gmm[06/27/06;16:35:03:785]addMember(GUID[lRX5wIWN5OQ4 UZy7Sbpwst8T6TE-]):StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:35:03:785]StringID[ecftcp://localhost:3282/server ]:3282:localhost:4362;queueObject(GUID[uiPQFsOLrfSqtKRztrjiZ ir7wns-],[B@1172e08)
(trace)connection[06/27/06;16:35:03:785]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(AsynchMessage[[B@1172e08])
(trace)connection[06/27/06;16:35:03:805]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;start()
(trace)connection[06/27/06;16:35:03:805]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;setupPing()
(trace)connection[06/27/06;16:35:19:758]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:35:19:758]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:35:20:860]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:35:20:860]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:35:22:262]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:35:22:262]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:35:25:797]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:35:25:807]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:35:36:252]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:35:36:252]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:35:37:363]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:35:37:363]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:35:38:755]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:35:38:765]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:35:42:311]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:35:42:311]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:35:52:776]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:35:52:776]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:35:53:867]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:35:53:867]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:35:55:259]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:35:55:259]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:35:58:884]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:35:58:894]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:36:09:289]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:36:09:289]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:36:10:371]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:36:10:371]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:36:11:763]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:36:11:763]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:36:15:388]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:36:15:388]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:36:25:793]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:36:25:793]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:36:26:875]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:36:26:875]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:36:28:267]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:36:28:267]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:36:31:892]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:36:31:902]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:36:42:287]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:36:42:297]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:36:43:368]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:36:43:378]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:36:44:770]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:36:44:770]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:36:48:396]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:36:48:396]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:36:58:791]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:36:58:791]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:36:59:872]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:36:59:882]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:37:01:274]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:37:01:274]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:37:04:899]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:37:04:899]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:37:15:294]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:37:15:294]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:37:16:376]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:37:16:376]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:37:17:768]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:37:17:778]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:37:21:403]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:37:21:403]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:37:31:798]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:37:31:798]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:37:32:880]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:37:32:880]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:37:34:272]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:37:34:272]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:37:37:907]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:37:37:907]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:37:48:302]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:37:48:302]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:37:49:383]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:37:49:383]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:37:50:775]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:37:50:775]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:37:54:411]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:37:54:421]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:38:04:805]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:38:04:805]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:38:05:887]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:38:05:887]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:38:07:279]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:38:07:279]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:38:10:924]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:38:10:924]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:38:21:309]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:38:21:309]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:38:22:391]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:38:22:391]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:38:23:783]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:38:23:783]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:38:27:418]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:38:27:428]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:38:37:813]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:38:37:813]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:38:38:894]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:38:38:894]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:38:40:307]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:38:40:307]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:38:43:922]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:38:43:932]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:38:45:784]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(AsynchMessage[[B@1888759])
(trace)container[06/27/06;16:38:45:784]processAsynch(org.eclipse.ecf.core.comm.AsynchConnectionEvent@f62373):StringID[ecftcp://localhost:3282/server]
(trace)container[06/27/06;16:38:45:784]handleSharedObjectMes sage:ContainerMessage[GUID[lRX5wIWN5OQ4UZy7Sbpwst8T6TE-];nul l;1;SharedObjectMessage[StringID[collab.editor.presence];[B@1f1fba0]]:StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:38:45:784]StringID[ecftcp://localhost:3282/server ]:3282:localhost:4362;queueObject(GUID[uiPQFsOLrfSqtKRztrjiZ ir7wns-],[B@f9f9d8)
(trace)connection[06/27/06;16:38:45:794]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(AsynchMessage[[B@f9f9d8])
(trace)connection[06/27/06;16:38:45:794]accept:/127.0.0.1
(trace)connection[06/27/06;16:38:45:804]serverrecv:ConnectRe questMessage[ecftcp://localhost:3282/server ;ContainerMessage[GUID[IZ3MCxYXJaX0p4JnI7mS_iqNkFI-];StringI D[ecftcp://localhost:3282/server];0;JoinGroupMessage[null]]]
(trace)connection[06/27/06;16:38:45:804]found container:ecftcp://localhost:3282/server for target ecftcp://localhost:3282/server
(trace)connection[06/27/06;16:38:45:804]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;setupThreads()
(trace)container[06/27/06;16:38:45:804]acceptNewClient(Socke t[addr=localhost/127.0.0.1,port=4371,localport=3282],/server ,ContainerMessage[GUID[IZ3MCxYXJaX0p4JnI7mS_iqNkFI-];StringI D[ecftcp://localhost:3282/server];0;JoinGroupMessage[null]],org.eclipse.ecf.provider.comm.tcp.Client@15b7986):StringID[ecftcp://localhost:3282/server]
(trace)container[06/27/06;16:38:45:804]addNewRemoteMember:GU ID[IZ3MCxYXJaX0p4JnI7mS_iqNkFI-]:StringID[ecftcp://localhost:3282/server]
(trace)gmm[06/27/06;16:38:45:804]addMember(GUID[IZ3MCxYXJaX0 p4JnI7mS_iqNkFI-]):StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:38:45:804]StringID[ecftcp://localhost:3282/server ]:3282:localhost:4363;queueObject(GUID[lRX5wIWN5OQ4UZy7Sbpws t8T6TE-],[B@a83b8a)
(trace)connection[06/27/06;16:38:45:804]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(AsynchMessage[[B@a83b8a])
(trace)connection[06/27/06;16:38:45:804]StringID[ecftcp://localhost:3282/server ]:3282:localhost:4362;queueObject(GUID[uiPQFsOLrfSqtKRztrjiZ ir7wns-],[B@723d7c)
(trace)connection[06/27/06;16:38:45:804]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;start()
(trace)connection[06/27/06;16:38:45:814]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;setupPing()
(trace)connection[06/27/06;16:38:45:814]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(AsynchMessage[[B@723d7c])
(trace)connection[06/27/06;16:38:54:317]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:38:54:317]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:38:55:398]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:38:55:398]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:38:56:810]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:38:56:810]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:00:425]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:39:00:435]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:08:697]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;recv(PingMessage)
(trace)connection[06/27/06;16:39:08:697]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:10:820]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:39:10:820]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:11:902]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:39:11:902]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:13:334]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:39:13:334]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:14:285]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;send(PingMessage)
(trace)connection[06/27/06;16:39:14:285]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:16:929]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:39:16:939]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:25:201]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;recv(PingMessage)
(trace)connection[06/27/06;16:39:25:201]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:27:324]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:39:27:324]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:28:406]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:39:28:406]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:29:838]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:39:29:838]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:30:789]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;send(PingMessage)
(trace)connection[06/27/06;16:39:30:789]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:33:433]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:39:33:433]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:41:715]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;recv(PingMessage)
(trace)connection[06/27/06;16:39:41:715]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:43:828]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:39:43:828]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:44:909]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:39:44:909]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:46:341]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:39:46:341]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:39:47:293]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;send(PingMessage)
(trace)connection[06/27/06;16:39:47:303]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:49:937]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingMessage)
(trace)connection[06/27/06;16:39:49:937]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingResponseMessage)
(trace)connection[06/27/06;16:39:58:219]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;recv(PingMessage)
(trace)connection[06/27/06;16:39:58:219]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;send(PingResponseMessage)
(trace)connection[06/27/06;16:40:00:332]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;recv(PingMessage)
(trace)connection[06/27/06;16:40:00:332]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(PingResponseMessage)
(trace)connection[06/27/06;16:40:01:413]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingMessage)
(trace)connection[06/27/06;16:40:01:453]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingResponseMessage)
(trace)connection[06/27/06;16:40:02:845]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;recv(PingMessage)
(trace)connection[06/27/06;16:40:02:845]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(PingResponseMessage)
(trace)connection[06/27/06;16:40:03:366]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;handleException in thread=StringID[ecftcp://localhost:3282/server]:rcvr:3282:localhost:4371
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:168)
at java.net.SocketInputStream.read(SocketInputStream.java:182)
at java.io.ObjectInputStream$PeekInputStream.peek(ObjectInputSt ream.java:2205)
at java.io.ObjectInputStream$BlockDataInputStream.peek(ObjectIn putStream.java:2495)
at java.io.ObjectInputStream$BlockDataInputStream.peekByte(Obje ctInputStream.java:2505)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1272)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 349)
at org.eclipse.ecf.provider.comm.tcp.Client.readObject(Client.j ava:520)
at org.eclipse.ecf.provider.comm.tcp.Client.access$4(Client.jav a:517)
at org.eclipse.ecf.provider.comm.tcp.Client$4.run(Client.java:3 59)
at java.lang.Thread.run(Thread.java:595)
(trace)container[06/27/06;16:40:03:376]processDisconnect[Str ingID[ecftcp://localhost:3282/server]:rcvr:3282:localhost:4371]:StringID[ecftcp://localhost:3282/server]
(trace)gmm[06/27/06;16:40:03:376]removeMember(GUID[IZ3MCxYXJ aX0p4JnI7mS_iqNkFI-]):StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:40:03:376]StringID[ecftcp://localhost:3282/server ]:3282:localhost:4363;queueObject(GUID[lRX5wIWN5OQ4UZy7Sbpws t8T6TE-],[B@fd13b5)
(trace)connection[06/27/06;16:40:03:376]StringID[ecftcp://localhost:3282/server ]:3282:localhost:4362;queueObject(GUID[uiPQFsOLrfSqtKRztrjiZ ir7wns-],[B@117a8bd)
(trace)container[06/27/06;16:40:03:376]killconnection(org.eclipse.ecf.provider.comm.tcp.Client@15b7986):StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:40:03:386]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;handleException in thread=StringID[ecftcp://localhost:3282/server]:rcvr:3282:localhost:4363
(trace)container[06/27/06;16:40:03:386]processDisconnect[Str ingID[ecftcp://localhost:3282/server]:rcvr:3282:localhost:4363]:StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:40:03:386]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;handleException in thread=StringID[ecftcp://localhost:3282/server]:rcvr:3282:localhost:4362
(trace)container[06/27/06;16:40:03:386]processDisconnect[Str ingID[ecftcp://localhost:3282/server]:rcvr:3282:localhost:4362]:StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:40:03:386]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;send(AsynchMessage[[B@fd13b5])
(trace)connection[06/27/06;16:40:03:396]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;send(AsynchMessage[[B@117a8bd])
(trace)connection[06/27/06;16:40:03:376]StringID[ecftcp://localhost:3282/server]:3282:localhost:4371;disconnect()
(trace)gmm[06/27/06;16:40:03:396]removeMember(GUID[lRX5wIWN5 OQ4UZy7Sbpwst8T6TE-]):StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:40:03:406]StringID[ecftcp://localhost:3282/server ]:3282:localhost:4362;queueObject(GUID[uiPQFsOLrfSqtKRztrjiZ ir7wns-],[B@fe64b9)
(trace)container[06/27/06;16:40:03:406]killconnection(org.eclipse.ecf.provider.comm.tcp.Client@1e63e3d):StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:40:03:416]StringID[ecftcp://localhost:3282/server]:3282:localhost:4363;disconnect()
(trace)connection[06/27/06;16:40:03:416]StringID[ecftcp://localhost:3282/server]:-1:<no endpoint>:-1;RCVR TERMINATING
(trace)connection[06/27/06;16:40:03:426]StringID[ecftcp://localhost:3282/server]:-1:<no endpoint>:-1;PING TERMINATING
(trace)gmm[06/27/06;16:40:03:426]removeMember(GUID[uiPQFsOLr fSqtKRztrjiZir7wns-]):StringID[ecftcp://localhost:3282/server]
(trace)container[06/27/06;16:40:03:426]killconnection(org.eclipse.ecf.provider.comm.tcp.Client@8ed465):StringID[ecftcp://localhost:3282/server]
(trace)connection[06/27/06;16:40:03:426]StringID[ecftcp://localhost:3282/server]:3282:localhost:4362;disconnect()
(trace)connection[06/27/06;16:40:03:436]StringID[ecftcp://localhost:3282/server]:-1:<no endpoint>:-1;RCVR TERMINATING
(trace)connection[06/27/06;16:40:03:436]StringID[ecftcp://localhost:3282/server]:-1:<no endpoint>:-1;SENDER TERMINATING
(trace)connection[06/27/06;16:40:03:436]StringID[ecftcp://localhost:3282/server]:-1:<no endpoint>:-1;PING TERMINATING
(trace)connection[06/27/06;16:40:03:416]StringID[ecftcp://localhost:3282/server]:-1:<no endpoint>:-1;SENDER TERMINATING
(trace)connection[06/27/06;16:40:03:446]StringID[ecftcp://localhost:3282/server]:-1:<no endpoint>:-1;SENDER TERMINATING
(trace)connection[06/27/06;16:40:03:466]StringID[ecftcp://localhost:3282/server]:-1:<no endpoint>:-1;PING TERMINATING
--------------080908050503030906040607--
| Re: can't get shared editing working [message #605235 is a reply to message #605225] |
Tue, 27 June 2006 13:54   |
Junior Member |
Jakub,
Ok, thanks for checking. The only thing I can think of is Eclipse
3.1.2. If you have a 3.2 release available, can you try that? I also
remember Scott mentioning some ECF plugin.xml schemas are not backward
compatible with 3.1. Scott, is this still the case?
Ken
> Hi Ken,
> Ken Gilmer wrote:
>> Hi Jakub,
>>> 1.
>>> the Navigator view, ECF->Open Shared Editor) in one session I receive a
>> ECF context menu. To initiate a shared editing session, context menu:
>> need to go file menu: new->team->shared editor session. From there
>> you should see the file shared from the original client. None of the
>> a client. If you follow these steps
>>> though I can't those changes in the second session. I'm also a bit
>>> confused about
>>> 2.
>>> Jakub
>>> Ken Gilmer wrote:
>>>> Hi Jakub,
>>>> preferences?
>>>> whiteboard example?
>>>> Thanks
>>>> Ken
>>>>> Hello,
>>>>> share an editor so that on is typing and the other can see
>>>>> changing. Everything works fine until I get to the point of
>>>>> creating a new Shared Editor Session. When I open the dialog Shared
>>>>> Editro I can't neither see nor choose Shared file, even though I
>>>>> connected the project before and also
>>>>> Jakub
| Re: can't get shared editing working [message #605244 is a reply to message #605235] |
Tue, 27 June 2006 18:20   |
Junior Member |
Ken Gilmer wrote:
> Jakub,
> Thanks
> Ken
I've tried 3.2 RC7 and the shared editor works there, so obviously the
problem was the Eclipse version:-(
Is there any possibility of get it working also in 3.1.2 ?
Thank you.
Jakub
>> Hi Ken,
>> Ken Gilmer wrote:
>>> Hi Jakub,
>>>> 1.
>>> menu: team->initiate shared session. For a second client to connect,
>>> you need to go file menu: new->team->shared editor session. From
>>> there you should see the file shared from the original client. None
>>> of the functionality is present in the ECF menu. I think this is
>>> something Scott did before I was involved with ECF.
>> log. And the ECF server's log (enclosed in the attachment) looks like
>> there is no problem either. But still, when I open
>> File->New->Team->Shared Editor Sesssion I can't see any files opened
>> for sharing there.
>>>> whether I
>>>> confused about
>>>> 2.
>>>> Jakub
>>>> Ken Gilmer wrote:
>>>>> Hi Jakub,
>>>>> preferences?
>>>>> whiteboard example?
>>>>> Thanks
>>>>> Ken
>>>>>> Hello,
>>>>>> shared editing working. I was carefully following the tutorial how
>>>>>> to share an editor so that on is typing and the other can see
>>>>>> Shared Editro I can't neither see nor choose Shared file, even
>>>>>> though I connected the project before and also
>>>>>> Jakub
>> in
>> at
>> at
>> at
>> at
>> in
>> at
>> at
>> at
>> at
>> in
>> at
>> at
>> at
>> at
| Re: can't get shared editing working [message #605248 is a reply to message #605235] |
Tue, 27 June 2006 18:29   |
Scott Lewis Messages: 942 Registered: July 2009 |
Hi Ken,
Ken Gilmer wrote:
> Jakub,
Not as of version 0.8.3 of ECF. I added "Eclipse-Autostart" to the
various plugins manifest.mf files so that the ECF plugins would run
properly on 3.1.2.
RE the logs...are you seeing any indication that the clients are
connecting to the server (on the server) when you Initiate Shared Editor
as described in http://wiki.eclipse.org/index.php/Example_Shared_Text_Editor
Thanks Jakub. Note that although it's no excuse we (ECF) are trying to
get our 'shared editor act together' over the next few months...probably
by changing/merging the various 'flavors' of shared editing into one
example application (perhaps with ability to present
Scott
> Thanks
> Ken
>> Hi Ken,
>> Ken Gilmer wrote:
>>> Hi Jakub,
>>>> 1.
>> for sharing there.
>>>> whether I
>>>> confused about
>>>> 2.
>>>> Jakub
>>>> Ken Gilmer wrote:
>>>>> Hi Jakub,
>>>>> preferences?
>>>>> whiteboard example?
>>>>> Thanks
>>>>> Ken
>>>>>> Hello,
>>>>>> Jakub
>> in
>> at
>> at
>> at
>> at
>> in
>> at
>> at
>> at
>> at
>> in
>> at
>> at
>> at
>> at
>> (trace)connection[06/27/06;16:40:03:416]StringID[Report message to a moderator
| Re: can't get shared editing working [message #605253 is a reply to message #605244] |
Tue, 27 June 2006 18:33   |
Hi Jakub,
> Hi
> Ken Gilmer wrote:
>> Jakub,
>> Thanks
>> Ken
As of 0.8.5+ it should work in 3.1.2. If 0.8.5 or more recent doesn't
please file an ECF bug report. Although I have to say given 3.2's
impending arrival (this week), supporting 3.1.2 is becoming less
important (I hope).
Thanks for the reports Jakub.
Scott
> Thank you.
> Jakub
>>> Hi Ken,
>>> Ken Gilmer wrote:
>>>> Hi Jakub,
>>>>> 1.
>>>>> receive a
>>>> connect, you need to go file menu: new->team->shared editor
>>>> session. From there you should see the file shared from the
>>>> original client. None of the functionality is present in the ECF
>>>> menu. I think this is something Scott did before I was involved
>>>> with ECF.
>>>> from a client. If you follow these steps
>>>> you get any exceptions in the eclipse error log or in the ECF server
>>>> trace?
>>> for sharing there.
>>>>> whether I
>>>>> confused about
>>>>> 2.
>>>>> Jakub
>>>>> Ken Gilmer wrote:
>>>>>> Hi Jakub,
>>>>>> in preferences?
>>>>>> whiteboard example?
>>>>>> Thanks
>>>>>> Ken
>>>>>>> Hello,
>>>>>>> how to share an editor so that on is typing and the other can see
>>>>>>> Jakub
>>> in
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> in
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> in
>>> at
>>> at
>>> at
>>> at
>>> at
| Re: can't get shared editing working [message #612055 is a reply to message #605253] |
Thu, 01 February 2007 12:19   |
Jonathon Golden Messages: 2 Registered: July 2009 |
Junior Member |
I'm using Eclipse 3.2.1 and ECF 0.9.6
I tried to start a shared editing session with another user and
everything worked except the editing part.
Here is what we did:
1. We both right clicked on our project, chose ECF and then Connect
Project. We both connected successfully to
ecftcp://ecf.eclipse.org:3282/server
2. I then right click on a file chose ECF and open a shared editor. The
other user receives a dialog asking to open a shared editing session
which he accepts and the file opens.
At this point we do not see each others changes. We tried to use the
share selection option from the left margin. It sent the message to the
other user and selects his text but does not show the other user's edits.
We have the exact same project structure and the chatting features work
fine.
Is this a know issue in this build or are we doing something wrong?
Jonathon
Scott Lewis wrote:
> Hi Jakub,
>> Hi
>> Ken Gilmer wrote:
>>> Jakub,
>>> also remember Scott mentioning some ECF plugin.xml schemas are not
>>> backward compatible with 3.1. Scott, is this still the case?
>>> Thanks
>>> Ken
> important (I hope).
> Scott
>> Thank you.
>> Jakub
>>>> Hi Ken,
>>>> Ken Gilmer wrote:
>>>>> Hi Jakub,
>>>>>> 1.
>>>>>> receive a
>>>>> with ECF.
>>>>> server trace?
>>>> like there is no problem either. But still, when I open
>>>> for sharing there.
>>>>>> whether I
>>>>>> confused about
>>>>>> changes).
>>>>>> 2.
>>>>>> Jakub
>>>>>> Ken Gilmer wrote:
>>>>>>> Hi Jakub,
>>>>>>> your ECF datashare server. Here are some things to check:
>>>>>>> in preferences?
>>>>>>> whiteboard example?
>>>>>>> Thanks
>>>>>>> Ken
>>>>>>>> Hello,
>>>>>>>> see changing. Everything works fine until I get to the point of
>>>>>>>> Jakub
>>>> in
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
| Re: can't get shared editing working [message #612056 is a reply to message #612055] |
Thu, 01 February 2007 12:59  |
Hi Jonathon,
I think this maybe a new issue. The shared editor is in the process of
being enhanced significantly by Mustafa Isik and Ken Gilmer so I'm
copying them on this response. Jonathon, would you be so good as to
file a bug on this issue at:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=ECF
Thanksinadvance,
Scott
Jonathon Golden wrote:
> fine.
> Jonathon
> Scott Lewis wrote:
>> Hi Jakub,
>>> Hi
>>> Ken Gilmer wrote:
>>>> Jakub,
>>>> Thanks
>>>> Ken
>> important (I hope).
>> Scott
>>> Thank you.
>>> Jakub
>>>>> Hi Ken,
>>>>> Ken Gilmer wrote:
>>>>>> Hi Jakub,
>>>>>>> 1.
>>>>>>> receive a
>>>>>> with ECF.
>>>>>> server trace?
>>>>> for sharing there.
>>>>>>> whether I
>>>>>>> confused about
>>>>>>> changes).
>>>>>>> 2.
>>>>>>> Jakub
>>>>>>> Ken Gilmer wrote:
>>>>>>>> Hi Jakub,
>>>>>>>> in preferences?
>>>>>>>> whiteboard example?
>>>>>>>> Thanks
>>>>>>>> Ken
>>>>>>>>> Hello,
>>>>>>>>> Jakub
>>>>> in
Current Time: Thu May 23 22:12:10 EDT 2013
Powered by FUDForum. Page generated in 0.03390 seconds
