Home » Modeling » B3 » Trouble installing b3 headless (3.6) under Windows
Trouble installing b3 headless (3.6) under Windows [message #611616] Fri, 27 August 2010 04:21
Daniel Weber is currently offline Daniel Weber
Member
I just tried to install the b3 aggregator:
Grabbed director_latest.zip, unzipped it and ran
director.bat -r http://download.eclipse.org/modeling/emft/b3/headless-3.6/ -d D:\tmp\b3 -p b3 -i org.eclipse.b3.cli.product -i org.eclipse.b3.aggregator.engine.feature.feature.group
The director says:
Installing org.eclipse.b3.cli.product 0.1.0.r01050.
And seems stuck after a while. Jars have been downloaded to D:\tmp\b3\plugins, but there is org.sat4j.core_2.2.0.v20100429.jar with a size of 0 bytes. When checking what the director process does using ProcessExplorer, it looks like it is downloading and unpacking that jar over and over again.
Any idea what could cause this?
I installed buckminster headless using a very similar commandline with the same director and it worked just fine (sat4j.core is included there as well). Also limiting the installation to org.eclipse.b3.cli.product only (omitting the aggregator feature) does not change a thing. The Eclipse log file contains only a few startup messages (framework argument etc).
Daniel
Previous Topic:missing requirement while aggregation the polarion update site whith b3 aggregator
Next Topic:multiple versions of a feature could not be mirrored
Current Time: Tue May 21 11:46:41 EDT 2013
Powered by FUDForum. Page generated in 0.07104 seconds
