| Re: missing requirement while aggregation the polarion update site whith b3 aggregator [message #611611 is a reply to message #611609] |
Wed, 04 August 2010 17:40  |
Filip Hrbek Messages: 233 Registered: July 2009 |
--------------010000090902090606020205
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Simon,
the problem is in the original repository definition. It contains features that require bundles that are filtered for win32 platform only. As soon as you verify your repository for a configuration different from win32, the verification fails.
You can modify your aggregation file to avoid this problem though. Add a Valid Configuration Rule to your mapped repository for each of the win32 specific features and assign the only valid configuration (win32/win32) to them. Then you should get no errors and it should be possible to mirror the repository. Adding a validation rule means that verification of matching feature will be skipped for all configurations other than those mentioned in the rule.
You will find an example of the aggregation definition with successful verification in the attached file.
Filip
Simon Linden wrote:
> Hello everybody,
> im trying to aggregate the subversion connectors from the http://community.polarion.com/projects/subversive/donwload/e clipse/2.0/update-site for a local update site and I'm getting this error:
> Cannot complete the install because one or more required items could not be found.
> Software being installed: all.contributed.content.feature.group 1.0.0
> Missing requirement: JavaHL 1.6.6 Win32 Binaries (Optional) 2.2.2.I20100512-1900 (org.polarion.eclipse.team.svn.connector.javahl16.win32.feat ure.group 2.2.2.I20100512-1900) requires 'org.polarion.eclipse.team.svn.connector.javahl16.win32 [2.2.2.I20100512-1900]' but it could not be found
> Cannot satisfy dependency:
> From: all.contributed.content.feature.group 1.0.0
> To: org.polarion.eclipse.team.svn.connector.javahl16.win32.featu re.group 0.0.0
> I added the update sitehttp://community.polarion.com/projects/subversive/donwlo ad/eclipse/2.0/update-siteas a "Mapped Repository" with no further configuration like "Bundles", "Features", Exclusion Rules" ...
> Can anybody confirm this issue or doing I something wrong?
> best regards & many thanks in advance
Content-Type: text/xml;
name="polarion.b3aggr"
Content-Disposition: attachment;
filename="polarion.b3aggr"
<aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:aggregator="http://www.eclipse.org/b3/2010/aggregator/1.0.0" label="Polarion">
<configurations/>
<configurations operatingSystem="linux" windowSystem="gtk"/>
<contributions label="Polarion">
<repositories location=" http://community.polarion.com/projects/subversive/donwload/e clipse/2.0/update-site">
<mapRules xsi:type="aggregator:ValidConfigurationsRule" name=" org.polarion.eclipse.team.svn.connector.javahl.win32.feature .group " validConfigurations="//@configurations.0"/>
<mapRules xsi:type="aggregator:ValidConfigurationsRule" name=" org.polarion.eclipse.team.svn.connector.javahl15.win32.featu re.group " validConfigurations="//@configurations.0"/>
<mapRules xsi:type="aggregator:ValidConfigurationsRule" name=" org.polarion.eclipse.team.svn.connector.javahl16.win32.featu re.group " validConfigurations="//@configurations.0"/>
</repositories>
</contributions>
<validationRepositories location="http://download.eclipse.org/releases/helios"/>
</aggregator:Aggregator>
--------------010000090902090606020205--
FUDForum. Page generated in 0.01936 seconds
