Home » Eclipse Projects » EclipseLink » Problems to use order by a null association(Jpql doesn't return the entities with nulls)
icon5.gif  Problems to use order by a null association [message #610099] Tue, 21 September 2010 16:56 Go to next message
No real name is currently offline No real name
Hello all!
I have two entities, A and B. A has manyToOne association with B. To list all A's ordered by B's in native sql I use this:
select * from A order by fk_idB
* fk_idB is the foreign key
But in jpql I use:
select a from A a order by a.b.idB
But now only the A's that has a B entity are returned. I need to return all A's! How I can do this?
Please someone help me!
Re: Problems to use order by a null association [message #628629 is a reply to message #610099] Thu, 23 September 2010 09:38 Go to previous message
Chris Delahunt is currently offline Chris Delahunt
The JPQL "select a from A order by a.b" might work as I believe EclipseLink has optimizations in place to just use the foriegn key. But the spec implies that using a '.' for a relationship should cause an inner join. So to be sure an outer join is used (for instance, if A doesn't have the foreign key), you may want to specify an outer join be used. For example:
"select a from A a outer join a.b b order by b"
Best Regards,
Chris
Previous Topic:How can I associate primary and secondary tables with a join criteria other than the compound key
Next Topic:Chain of eager relationships
Current Time: Sun May 19 22:56:23 EDT 2013
Powered by FUDForum. Page generated in 0.01621 seconds
