| NPE on RemoteService call with no parameters [message #609987] |
Thu, 14 December 2006 07:13  |
Paul Woodward Messages: 11 Registered: July 2009 |
Junior Member |
------=_Part_734_7217988.1166098460794
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Hi Guys,
RemoteCallImpl.toString() calls Arrays.asList with the list of parameters which will fail with a NPE if there are none.
I've attached a simple patch that works for me.
Regards, Paul
Content-Type: text/plain; name=patch.txt; charset=us-ascii
Content-Disposition: attachment; filename=patch.txt
### Eclipse Workspace Patch 1.0
#P org.eclipse.ecf.provider.remoteservice
Index: src/org/eclipse/ecf/provider/remoteservice/generic/RemoteCal lImpl.java
RCS file: /cvsroot/technology/org.eclipse.ecf/plugins/org.eclipse.ecf. provider.remoteservice/src/org/eclipse/ecf/provider/remotese rvice/generic/RemoteCallImpl.java,v
retrieving revision 1.3
diff -u -r1.3 RemoteCallImpl.java
--- src/org/eclipse/ecf/provider/remoteservice/generic/RemoteCal lImpl.java 25 Nov 2006 05:45:37 -0000 1.3
+++ src/org/eclipse/ecf/provider/remoteservice/generic/RemoteCal lImpl.java 14 Dec 2006 12:12:59 -0000
@@ -58,7 +58,7 @@
buf.append("class=").append(clazz).append(";");
buf.append("method=").append(method)
.append(";");
- buf.append("params=").append(Arrays.asList(parameters)).append( ";");
+ buf.append("params=").append(parameters == null ? "" : Arrays.asList(parameters)).append(";");
buf.append("timeout=").append(timeout).append("]");
return buf.toString();
------=_Part_734_7217988.1166098460794--
| Re: NPE on RemoteService call with no parameters [message #609989 is a reply to message #609987] |
Thu, 14 December 2006 18:28  |
Scott Lewis Messages: 942 Registered: July 2009 |
Hi Paul,
Thanks for the bug report and fix. I've created a bug, added patch as
attachment, applied the patch and marked bug as fixed.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168139
Again, thanks Paul!
Scott
Paul Woodward wrote:
> Hi Guys,
> Regards, Paul
> @@ -58,7 +58,7 @@
> .append(";");
FUDForum. Page generated in 0.02518 seconds
