Home » Eclipse Projects » Eclipse Communications Framework (ECF) » IBM Websphere MQSeries JMS provider
IBM Websphere MQSeries JMS provider [message #609984] Mon, 11 December 2006 01:19 Go to next message
John Chan is currently offline John Chan
Is there a JMS provider for IBM Websphere MQSeries 5.3 available? Also, this might sound stupid - how do I make use of the example plugin?
Re: IBM Websphere MQSeries JMS provider [message #609986 is a reply to message #609984] Mon, 11 December 2006 03:56 Go to previous message
Remy Suen is currently offline Remy Suen
I don't believe there's a provider for MQ, but if someone can correct
me, please do.
The org.eclipse.ecf.example.collab plug-in assumes you have some other
plug-ins installed. If you had the org.eclipse.ecf.provider.xmpp
plug-in, you'd be able to login to an XMPP account and see who's online
in your list of contacts.
The main entry point of the plug-in would be the workspace connection
toolbar item at the top, I suppose.
Rem
Previous Topic:ECF 0.9.4 stable + project plan for next releases
Next Topic:NPE on RemoteService call with no parameters
Current Time: Sat May 25 00:56:55 EDT 2013
Powered by FUDForum. Page generated in 0.01820 seconds
