Home » Modeling » GMT (Generative Modeling Technologies) » [TCS] Language Project example and dependent project's version
[TCS] Language Project example and dependent project's version [message #609301] Thu, 22 November 2007 09:08
Gustavo Cabral is currently offline Gustavo Cabral
Hi everyone,
I have tried the TCS/Language Project example
(http://wiki.eclipse.org/TCS/Language_Project) with metamodel and
syntax from the LOTOS example
(http://www.eclipse.org/m2m/atl/usecases/FIACRE2LOTOS/) but I just cant
make
it work!
I am using:
- the latest classic eclipse,
- updating with the EMF plugin,
- downloading the latest ATL plugin (I also install a build I
made from the CVS)
....but no success!
I think it is some major problem with the Eclipse X ATL X EMF versions. I
re-compiled and installed the latest version of ATL from the CVS
repository
but it didnt work. The classes:
org.eclipse.m2m.atl.engine.AtlEMFModelHandler;
org.eclipse.m2m.atl.engine.AtlModelHandler;
import org.eclipse.gmt.tcs.injector.TCSInjector;
org.eclipse.m2m.atl.engine.EnginePlugin;
org.eclipse.m2m.atl.engine.MarkerMaker;
cannot be found when I try to compile the "TCS Builder plugin" and the
"TCS Wizard plugin".
Through the ant approach, I get the following error:
BUILD FAILED
/home/gustavo/Desktop/eclipseClassicX/workspace/AMMAScripts/ build.dsl.xml:55:
The following error occurred while executing this line:
/home/gustavo/Desktop/eclipseClassicX/workspace/AMMAScripts/ build.dsl.xml:78:
/home/gustavo/Desktop/eclipseClassicX/workspace/AMMAScripts/ build.metamodel.xml:68:
Problem: failed to create task or type am3.loadModel
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken
place.
Can any one help me? What versions should I use?
Thank you for your time,
Gustavo Cabral
Previous Topic:Re: How build DD Model with UML metamodel
Next Topic:Re: How build DD Model with UML metamodel
Current Time: Sun May 19 17:06:22 EDT 2013
Powered by FUDForum. Page generated in 0.01614 seconds
