Home » Eclipse Projects » EclipseLink » EclipseLink Workbench source code?
EclipseLink Workbench source code? [message #558912] Tue, 14 September 2010 16:31 Go to next message
No real name is currently offline No real name
Is there a source code of EclipseLink Workbench??
Re: EclipseLink Workbench source code? [message #559211 is a reply to message #558912] Wed, 15 September 2010 21:44 Go to previous messageGo to next message
Doug Clarke is currently offline Doug Clarke
The EclipseLInk utilities are developed within the EclipseLink SVN repository. You can find the workbench source, libs and test at:
http://dev.eclipse.org/svnroot/rt/org.eclipse.persistence/tr unk/utils/
You should be able to check it out anonymously.
Doug
Re: EclipseLink Workbench source code? [message #559401 is a reply to message #559211] Thu, 16 September 2010 10:24 Go to previous messageGo to next message
Thanks.
EclipseLink Workbench is a great pieace of Swing UI code. It contains a mini general purpose UI framework inside...
Re: EclipseLink Workbench source code? [message #559913 is a reply to message #559211] Mon, 20 September 2010 07:07 Go to previous messageGo to next message
Craig Warren is currently offline Craig Warren
I've had a look through the source code you linked to, but can't find the part I'm looking for.
Do you know where I can find the source code for the workbench ant tasks?
Specifically ExportDeploymentXMLTask.class
I'm having some problems with its "failonerror" property not working properly.
Re: EclipseLink Workbench source code? [message #609255 is a reply to message #558912] Tue, 21 September 2010 16:45 Go to previous message
Les Davis is currently offline Les Davis
You should find the source for the ant tasks in the following directory: mappingsplugin\source\org\eclipse\persistence\tools\workbenc h\ant\taskdefs
Previous Topic:Just setting a property causes an sql update
Next Topic:PrivateOwned dont work in Embeddable class
Current Time: Tue May 21 03:00:54 EDT 2013
Powered by FUDForum. Page generated in 0.02136 seconds
