Home » Modeling » B3 » question/issue : changing ~= operator to ?=
question/issue : changing ~= operator to ?= [message #608293] Fri, 04 June 2010 21:38
Henrik Lindberg is currently offline Henrik Lindberg
after having typed ~= many times and found it very irritating in Eclipse
editors that the sequence to enter this has to be:
'~' ' '|'<esc>' '='
whereas it in the native mac is fine to type just '~' '='.
In Eclipse any character after ~ that it does not recognize as
composable deletes the ~ character.
All Eclipse editors (I tried) have the same behavior.
('vi' works fine though ;) )
I have the same issue when entering a regexp ~/.../.
How does this work on the Linux and Windows versions of Eclipse (try it
in a Java editor for instance).
Anyway, this has led me to consider replacing the use of ~ with ?. i.e.
'~=' becomes '?=' and patterns become ?/../ for regexp and ?" " for
simple pattern.
- henrik
Previous Topic:Maven2 Repositories
Next Topic:issues with property terminal
Current Time: Sat May 25 11:29:04 EDT 2013
Powered by FUDForum. Page generated in 0.01409 seconds
