Home » Modeling » GMT (Generative Modeling Technologies) » [TCS]:Build faied in injecteur and Extracteur
[TCS]:Build faied in injecteur and Extracteur [message #608165] Wed, 17 October 2007 17:42
Eclipse User
Originally posted by: youssedek.gmail.com
hi,
I have a problem to test the Program example indeed I have make all the
phases quoted in the toterials(TCS/Language Project) but when I excute the
injector it gives me a mesage: the parser is untraceable
Buildfile: /home/ydkiouak/Desktop/eclipse/Program/Injecteur_build.xml
injection:
BUILD FAILED
/home/ydkiouak/Desktop/eclipse/Program/Injecteur_build.xml:5 : Problem:
failed to create task or type eclipse.convertPath
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken
place.
others,the injecteur generate the empty text file.???
P.S:I'm configure the injecteur in this order:
<property name="extension" value="pgrm"/>
<property name="sample" value="AlarmClock"/>
<property name="sourceModel" value="${sample}.xmi"/>
<property name="targetModel" value="${sample}.${extension}"/>
<property name="TCSMMLocation" value="/AMMACore/TCS/Metamodel/TCS.ecore"
hank you for your explanations
thnx
Youssef
Previous Topic:scenario
Next Topic:[TCS] "Unable to determine generatted class" error
Current Time: Sun May 26 05:36:01 EDT 2013
Powered by FUDForum. Page generated in 0.07645 seconds
