Home » Modeling » B3 » Branchpoint - literals or expressions?
Branchpoint - literals or expressions? [message #608082] Thu, 20 May 2010 16:40
Henrik Lindberg is currently offline Henrik Lindberg
currently branch points are literals (i.e. timestamp, revision, or tag).
This means they can not be set from properties (as this requires
evaluation). I think that should be possible.
I can still provide validation and code completion for the most common
case of using a literal string, and issue warnings that validation is
deferred until runtime if the expression is more complex.
Agree?
- henrik
Previous Topic:repository syntax
Next Topic:Branches syntax
Current Time: Wed May 22 00:14:34 EDT 2013
Powered by FUDForum. Page generated in 0.01612 seconds
