Home » Modeling » Papyrus » Papyrus Extensions
Papyrus Extensions [message #605981] Wed, 04 August 2010 16:36 Go to next message
Keyla  is currently offline Keyla
I have 2 major doubts:
1)Is it possible to add new sub menus to the new Papyrus version on Eclipse Helios (like an extension)? Is there a tutorial somewhere that I could use?
2) Can I configure something on Acceleo to convert a SysML diagram to SystemC?
Please, I really need help, I have to make those modifications as part of a "home work" at college.
Re: Papyrus Extensions [message #606909 is a reply to message #605981] Thu, 26 August 2010 03:34 Go to previous message
Patrick Tessier is currently offline Patrick Tessier
For submenu, its possible, you can use extension point popmenu or ui.menus.
Some userguide will be added to explain that.
Convert a diagram is more difficult, do you want remove SysML stereotype and
add new stereotype for System C? or do you want a dedicated diagram for
system C, with new figure new beahvior for element?
"Keyla" <keylamacharet@gmail.com> a
Previous Topic:add interaction operands to a combined fragment
Next Topic:Papyrus Extensions
Current Time: Fri May 24 12:11:05 EDT 2013
Powered by FUDForum. Page generated in 0.01575 seconds
