Home » Eclipse Projects » Plugin Development Environment (PDE) » featureAndBundle publisher configuration
featureAndBundle publisher configuration [message #606449] Tue, 10 August 2010 09:18
Mikael Barbero is currently offline Mikael Barbero
I'm using the featureAndBundle (the application, not the ANT task) publisher to publish my features and I would like to tune some bits. Can you tell me if it is possible to :
- change the names of the artifacts and metadata repositories ? Currently, the publisher sets it to the local full path (/home/me/...).
- the id of of the some units in the metadata repository. For instance, for each published feature, the publisher creates two units: one suffixed with 'feature.group' and one suffixed with 'feature.jar'. I would like to change these suffixes.
Thanks for the answer.
Best regards.
Mikael
Mikael Barbero
Obeo
Previous Topic:featureAndBundle publisher configuration
Next Topic:Quasimodal Commands
Current Time: Sat May 25 01:30:55 EDT 2013
Powered by FUDForum. Page generated in 0.01617 seconds
