Home » Eclipse Projects » Plugin Development Environment (PDE) » How to add a popupMenu to a view
How to add a popupMenu to a view [message #606432] Thu, 05 August 2010 02:06 Go to next message
duanf  is currently offline duanf
I want to add a popupMenu to a view[id=com.my.MyView].The plugin.xml fragment as follow:
<viewerContribution
id="com.rational.test.ft.advance.sampleViewerContribution"
targetID="com.my.MyView">
<action
id="com.rational.test.ft.advance.viewerActionTest"
label="Sample Viewer Operation"
class="com.rational.test.ft.advance.actions.SampleViewerAction "
menubarPath="additions">
</action>
</viewerContribution>
This does not work.I can see the menu Item.
When I set the targetID ="org.eclipse.jdt.ui.PackageExplorer"..It works and I can see the menu item.
I am sure that MyView can work.Which difference between these two views may cayse this problem.
I just know the MyView is created by me ,which the view PackageExplorer is not.
Re: How to add a popupMenu to a view [message #606443 is a reply to message #606432] Thu, 05 August 2010 09:28 Go to previous message
I have known.
Should complete the function createPartControl(Composite parent)
Previous Topic:How to add a popupMenu to a view
Next Topic:Changing permissions or root files
Current Time: Sat May 25 23:30:20 EDT 2013
Powered by FUDForum. Page generated in 0.01869 seconds
