Home » Eclipse Projects » Dali » How to influence mapping type
How to influence mapping type [message #606103] Thu, 13 September 2007 09:15
Bart Kummel is currently offline Bart Kummel
We use Dali to generate Entities from tables. When we do this, every
numeric database field is mapped as a BigDecimal type. Most of the numeric
fields in the database have only 7 digits, so they should fit in a normal
Integer or int. We have a lot of numeric fields, so we don't want to
manually edit all entities. Is there a way to tell Dali that it should use
Integers for database fields which fit?
We have an IBM AS/400 database and are using TopLink JPA as EJB3
implementation.
Bart Kummel
Previous Topic:It works, but does not compile (only half a joke!)
Next Topic:NPE Generating Entity
Current Time: Sat May 25 15:49:31 EDT 2013
Powered by FUDForum. Page generated in 0.01522 seconds
