| launching JUnit plugin-test from command Prompt [message #605649] |
Wed, 21 April 2010 18:15  |
Ram Messages: 3 Registered: April 2010 |
Junior Member |
I have created a plugin and have a JUnit pluin-test code that will launch this plugin. This plugin, basically opens the eclipse, perform some tasks, collect data and close the eclipse instance. Couldn't find much help with the internet. Any help on this is appreciated.
I m using Eclipse 3.3.2.
I tried the equinox launcher to launch the application. The eclipse opens up, but then, it closes throwing an exception
Could not connect to: : 1564
java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:352)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.ja va:214)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:201)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:377)
at java.net.Socket.connect(Socket.java:530)
at java.net.Socket.connect(Socket.java:480)
at java.net.Socket.<init>(Socket.java:377)
at java.net.Socket.<init>(Socket.java:191)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.conne ct(RemoteTestRunner.java:560)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:377)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:58)
at org.eclipse.pde.internal.junit.runtime.UITestApplication$1.r un(UITestApplication.java:122)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:129)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.pde.internal.junit.runtime.UITestApplication.sta rt(UITestApplication.java:52)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:599)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
58777 [main] DEBUG AdoptionTrackingActivator - adoption tracking plugin stops
Should I set the port anywhere in the code or should I write a listener that will listen to this port? I need to get this resolved as soon as possible. Any help on this is appreciated.
Ram
FUDForum. Page generated in 0.02567 seconds
