Home » Modeling » UML2 » UML2 source has moved
UML2 source has moved [message #605404] Tue, 03 April 2007 17:02
Kenn Hussey is currently offline Kenn Hussey
The source for UML2 has moved (finally) to its new CVS home at
/cvsroot/modeling/org.eclipse.mdt/org.eclipse.uml2. Thanks to our build
engineer, Nick Boldt, for helping make this happen.
I've also added a project set file,
/cvsroot/modeling/org.eclipse.mdt/org.eclipse.uml2.releng/um l2.psf, which
can be used to easily check out all of the required projects.
Kenn
Previous Topic:UML2 source has moved
Next Topic:Behavior and Profiles in metamodeling
Current Time: Mon May 20 16:28:13 EDT 2013
Powered by FUDForum. Page generated in 0.01408 seconds
