Home » Eclipse Projects » XML Schema Definition (XSD) » xmi Models
xmi Models [message #604473] Mon, 22 February 2010 08:15 Go to next message
shekoufeh Missing name is currently offline shekoufeh Missing name
I am trying to do transformation in QVT.
I have been creating my ecore metamodels and tried to generate dynamic instance of them, the instance is not readable.
when I open it by text edittor the schemalocation is like "null ../metamodels/Node.ecore"
I remove null .. and add platform:/resource/metamodels/Node.ecore
but still not working
Do u have any idea how should I encounter with this problem
Many thanks,
SH
Re: xmi Models [message #604477 is a reply to message #604473] Mon, 22 February 2010 09:54 Go to previous message
Ed Merks is currently offline Ed Merks
SH,
Does your EPackage have a non-null nsURI? That first value should be
the namespace of the model. If you right click on the EClass in the
Sample Ecore Editor and invoke "Create Dynamic Instance" you should get
something that works. I'm not sure how you're creating what you
describe below.
> Many thanks,
> SH
Previous Topic:[Announce] Eclipse/OMG Symposium 2010
Next Topic:xmi Models
Current Time: Wed May 22 13:07:20 EDT 2013
Powered by FUDForum. Page generated in 0.01504 seconds
