Home » Eclipse Projects » Plugin Development Environment (PDE) » My Job's Progress Bar Won't Go Away
My Job's Progress Bar Won't Go Away [message #604201] Sat, 16 January 2010 17:49 Go to next message
Scott Hamilton is currently offline Scott Hamilton
This is my first plugin, so be gentle. :) I can't figure this out!
I have a task that the user initiates with a button on my plugin view. This task can take a while so I put it into a Job and schedule it for ASAP execution. If I use the IProgressMonitor given to my job's run() method such that in the run method I call monitor.beginTask(String,int) and then monitor.worked(1) for each unit of work done, then in a finally block call monitor.done(), MOST of the time the progress view's job will not only show up and grow the progress indicator bar across from left to right, but it will also:
1. Not move it to 100% but some percentage short (seems consistent how far it goes), and
2. Not remove the job from the progress view.
Debugging shows me that (a) no errors occur in my code, (b) I in fact DO call monitor.worked(1) the exact # of times that match the 2nd parameter to monitor.beginTask(), and (c) monitor.done() is definitely called.
AND... here's the really painful part: if I set a breakpoint on monitor.done(), then continue VM execution, the progress job disappears as it should.
So it seems like some kind of race condition perhaps, since when I trigger this breakpoint I'm stopping the job's thread but not all threads?
One last bit to throw into play: when the job thingie lingers, the cancel button in the progress window for this job is still red and active, and I can click it and the job disappears. So it is not like the progress monitor thinks the job is done and just waiting for me to dismiss it.
So... anyone know what is going on here?
I'm baffled!
(PS. if I stop using monitor.beginTask(), worked() and done() altogether, while I don't see the progress bar, the job DOES seem to go away when done pretty consistently.)
Re: My Job's Progress Bar Won't Go Away [message #604227 is a reply to message #604201] Mon, 18 January 2010 00:22 Go to previous message
Prakash G.R. is currently offline Prakash G.R.
> far it goes), and
What you have done seems to be right. Can you attach a sample code to
reproduce it?
- Prakash
Platform UI Team, IBM
Blog <http://blog.eclipse-tips.com>
Twitter <http://www.twitter.com/Eclipse_Tips>
Previous Topic:API Tools - No warnings/errors when changing API
Next Topic:plugin with POI
Current Time: Tue May 21 09:14:29 EDT 2013
Powered by FUDForum. Page generated in 0.01515 seconds
