Home » Eclipse Projects » DSDP - Tools for Mobile Linux (TML) » Call for participation: TM 3.1m5 test pass on 1-Feb-2009
Call for participation: TM 3.1m5 test pass on 1-Feb-2009 [message #589] Mon, 26 January 2009 11:37 Go to next message
Martin Oberhuber is currently offline Martin Oberhuber
Dear wider TM / RSE Community,
as you're probably aware, the upcoming M5 build of the Eclipse Galileo
Train projects is what's going to go on a USB key for EclipseCon. The
Target Management / RSE team therefore invites all interested parties to
do a test pass on the TM 3.1m5 candidate
on Monday, Feb. 1 2009
Why should you join?
- If you use TM as a dependency for your offering, you may want to
check that the stuff you need works in m5
What can you do?
- Just try out the stuff that you'd like to work fine, and file
a bug if it doesn't. We'll provide a bug reporting template
for you, so it's super fast and easy to participate.
How long will it take you?
- If you've just got 1 hour for downloading, installing and trying
it out that's a very valuable input for us already. Of course
you're free to report enhancement requests as well!
Any additional information like the test candidate to download,
bug reporting template, and other information will be on
http://wiki.eclipse.org/DSDP/TM/Testing/3.1m5
For any other questions, please contact us on the TM mailing list:
https://dev.eclipse.org/mailman/listinfo/dsdp-tm-dev
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Re: Call for participation: TM 3.1m5 test pass on 1-Feb-2009 [message #604 is a reply to message #589] Sun, 01 February 2009 21:37 Go to previous message
Hi all,
Test downloads for TM 3.1m5 have been uploaded, the Wiki page has
been updated: http://wiki.eclipse.org/DSDP/TM/Testing/3.1m5
Latest news: The "GSoC Team Synchronize" integration didn't make
it into this test build, but will be added for M5.
Thanks in advance for your testing TM 3.1m5!
> What can you do?
Re: Call for participation: TM 3.1m5 test pass on 1-Feb-2009 [message #562020 is a reply to message #589] Sun, 01 February 2009 21:37 Go to previous message
Hi all,
> What can you do?
Previous Topic:Call for participation: TM 3.1m5 test pass on 1-Feb-2009
Next Topic:Extension Point for New VNC Connections
Current Time: Wed May 29 04:03:19 EDT 2013
Powered by FUDForum. Page generated in 0.10446 seconds
