I am creating a plugin for ffaster view development.
The scenario is a user selects a java file and clicks on New --> View then he gets a list of all the attributes defined in the java file.
I am using Reflection to get all the attributes and methods of the java class.
I need a class object to give as input to reflection class. I am not able to get the class object of java file selected.
It is able to find classes those are present in Plugin code.
On 12/29/2009 11:43 AM, neha.pandey@lntinfotech.com wrote:
> class. I need a class object to give as input to reflection class. I am
> Kindly Help.
> Its very urgent.
I believe a better approach would be to hook into CNF to see the selected class and then use JDT.
You may also have a look the way outline view shows the class outline, sounds like you are trying to
achieve something similar.
Ankur..
Eclipse PDE UI Committer | IBM India Software Lab, Bangalore
+91-99456-94011 | @ankur_sharma | http://blog.ankursharma.org
