Home » Eclipse Projects » Plugin Development Environment (PDE) » Issues about LabelProvider and TreeViewer
Issues about LabelProvider and TreeViewer [message #603441] Fri, 20 November 2009 03:35 Go to next message
Javier  is currently offline Javier
Hi Folks:
Firts of all, thanks for you help. I talk you about my problem:
I'm developing a plug-in to parser a file and view the results as a tree, using a TreeViewer. For each leaf, I use a LabelProvider with a text and icon. I have a class that extends LabelProvider and here, I've implemented methods getText() and getImage(). I see, the icon is always in the first position and then the text. Is there any way to change that? I'd like to put the text first and icon, next.
If that is not possible, is there any other way to paint a tree, putting text and icon? Using another class instead of TreeViewer? I hope I've explained well.
Your comments will be well received.
Thank you very much.
Re: Issues about LabelProvider and TreeViewer [message #603857 is a reply to message #603441] Wed, 23 December 2009 12:21 Go to previous message
Andreas Hoegger is currently offline Andreas Hoegger
Hi Javier
a possible solution would be painting by yourself. You should be able to
implement it analog the table example (following the link).
http://www.eclipse.org/articles/Article-CustomDrawingTableAn dTreeItems/index.html#_tr12J
BR
Andreas
Javier wrote:
> Hi Folks:
> explained well.
Previous Topic:Inject Update Site URL into top-level feature
Next Topic:Issues about LabelProvider and TreeViewer
Current Time: Sat May 25 03:58:07 EDT 2013
Powered by FUDForum. Page generated in 0.08253 seconds
