Home » Eclipse Projects » Plugin Development Environment (PDE) » IPluginModelBase listener + stale information
IPluginModelBase listener + stale information [message #603822] Thu, 17 December 2009 16:59
James Willans is currently offline James Willans
Member
I am adding a listener to instances of IPluginModelBase using the
following code:
private void bundleAdded(final IPluginModelBase pluginModel) {
// Create a new bundle to model the one added
pluginModel.addModelChangedListener(new IModelChangedListener() {
public void modelChanged(IModelChangedEvent event) {
System.out.println("** Change event **");
String id = pluginModel.getPluginBase().getId();
String version = pluginModel.getPluginBase().getVersion();
System.out.println("id : " + id);
System.out.println("Version: " + version);
When I change and save the bundle details in the manifest editor, I seem
to be getting stale information. For example, assuming that the bundle
id is "BundleA" and the version is 1.0:
1) Bundle id is changed to "BundleB" the output is correct:
** Change event **
Version: 1.0.0
2) Bundle version is changed to "2.0.0" the event is fired but the
output is stale:
** Change event **
Version: 1.0.0
3) Bundle version is changed to "3.0.0" the output continues to be stale:
** Change event **
Version: 2.0.0
This is similarly the case when monitoring the dependencies and other
features of the model. What am I doing wrong?
James
Previous Topic:Trouble with headless build since Eclipse 3.5
Next Topic:Test Architecture causes Dependency Cycle
Current Time: Fri May 24 15:03:15 EDT 2013
Powered by FUDForum. Page generated in 0.01505 seconds
