| Adding a list with multiple Columns to a PreferencePage [message #603802] |
Mon, 14 December 2009 06:58  |
Martin D Messages: 7 Registered: December 2009 |
Junior Member |
The standard PDE way of adding Preference is to use field editors (for Boolean, String, Integer..) and subclass FieldEditorPreferencePage.
I'd like to integrate a list similar to the 'Network Connections' List in Preferences. A Basic List with Add / Edit / Remove functionality for multiple columns.
I'm intrested how this List is implemented
I tryed to find the Class Presenting the "Network Connections List"
in the Eclipse sourceBuild by searching for strings appearing on the UI but no results.
Can you help?
FUDForum. Page generated in 0.13934 seconds
