Home » Eclipse Projects » XML Schema Definition (XSD) » XSDRedefinableComponent
XSDRedefinableComponent [message #603597] Fri, 09 January 2009 04:22
Joachim is currently offline Joachim
Having a look into XSD.ecore in org.eclipse.xsd_2.4.1.v200808251517.jar,
I see that the abstract EClass "XSDRedefinableComponent" has the
abstract ESuperType "XSDRedefineContent".
All non abstract EClasses which have ESuperType
"XSDRedefinableComponent", e.g. "XSDAttributeGroupDefinition",
"XSDModelGroupDefinition", "XSDTypeDefinition" also have ESuperType
"XSDRedefineContent". The EClass "XSDRedefinableComponent" is never
inherited without also inherting "XSDRedefineContent".
So, the EClass "XSDRedefineContent" is inherited directly AND indirectly.
Is there any special reason for such a - I tend to say bad - modeling?
Will the direct inheritance be removed in later versions?
Joachim Back
Previous Topic:XSDSimpleTypeDef validation
Next Topic:XSDRedefinableComponent
Current Time: Tue May 21 18:16:51 EDT 2013
Powered by FUDForum. Page generated in 0.03241 seconds
