Home » Eclipse Projects » XML Schema Definition (XSD) » Dynamic Instance of XSD.ecore
Dynamic Instance of XSD.ecore [message #603202] Tue, 05 August 2008 04:56
Tim Brömme is currently offline Tim Brömme
I was just trying to use the EMF feature to create dynamic instances of
an ecore file (right click on elment in ecore file -> create dynamic
instance).
If u use this feature on the root element of your model, you are able to
create
an instance of your metamodel without generating an editor.
as I said, I tried this with the XSD.ecore file, but there seems to be a
problem.
These are my steps:
1. Open XSD.ecore with "Sample Ecore Model Editor"
2. Right Click on "XSD Schema -> XSD Scope"
3. "Create Dynamic Instance"
4. Open resulting file with "Sample Reflective Ecore Model Editor"
5. Right Click on "XSD Schmema" -> "new Child" -> "Contents XSD Element
Declaration"
6. Save Model, Close File
7. Open File again -> Several Errors raise ("Value #null is not legal")
These same steps I do with other *.ecore files and it works perfectly.
Most of these are handmade by me / us at TU Berlin, the XSD.ecore is one
of the few which came from "outside".
The first guess is, that "XSD Schema" is not the root element of the XSD
Metamodel, but I have no idea which other element could be the root.
Maybe the problem is somewhere else. Do you have an idea ?
Thanks in adavance,
Tim
Previous Topic:XML and XSD models from string
Next Topic:XSD to Ecore order attributes
Current Time: Sat May 18 22:24:07 EDT 2013
Powered by FUDForum. Page generated in 0.06271 seconds
