| Plugin for "Check update" menu item [message #601478] |
Sun, 13 June 2010 03:25  |
pop prem Messages: 20 Registered: June 2010 |
Junior Member |
Hi all,
I've given a task to create a plugin which is similar to Mylyn updater but it should only have "Check for update" menu item with the url defined. So, if this plugin is added to a rcp application, in the help menu it should add "Check for update" menu item and when click on that, it should go to the defined site (url hardcoded) and display the list of addons available in the same way how Mylyn discovery updater does.
I understand that i can build this plugin from the code of Mylyn discovery Updater, but not getting the right idea on how to do this. I would really appreciate if anyone can give me some ideas on how to proceed with this work. Looking for your brilliant ideas.
Thanks in advance.
Prasath.
| Re: Plugin for "Check update" menu item [message #601482 is a reply to message #601478] |
Mon, 14 June 2010 14:26  |
Steffen Pingel Messages: 704 Registered: July 2009 |
I would recommend looking at P2 examples on how to add update and extension
install to RCP applications:
http://wiki.eclipse.org/Equinox/p2/Adding_Self-Update_to_an_ RCP_Application
http://wiki.eclipse.org/Equinox/p2/Discovery
Steffen
popprem wrote:
> Hi all,
> Thanks in advance.
> Prasath.
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
FUDForum. Page generated in 0.01551 seconds
