| [SOLVED] UML2API basics [message #502693] |
Wed, 09 December 2009 08:17  |
Stefan Messages: 13 Registered: October 2009 |
Junior Member |
i am currently playing around with the uml2 implementation in the emf project.
as a starting point i have a UML-class-diagram with a UML-OWL-Profile applied. I am doing this according to the "Getting start with UML2" tutorial.
Now i load the UML-class-diagram like this (i am doing it in a stand alone application just for testing at the moment, later maybe in a eclipse-plugin):
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Map uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI("jar:file:/C:/eclipse/plugins/org.eclipse.uml2.uml.resources_3.0.0.v200906011111.jar!/");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
URI modelFile = URI.createFileURI("src/m3o-profiled.uml");
URI profileFile = URI.createFileURI("src/OWL.profile.uml");
UMLResource modelResource = (UMLResource)resourceSet.getResource(modelFile, true);
UMLResource profileResource = (UMLResource)resourceSet.getResource(profileFile, true);
i can iterate over the Model and get any information i want, but i can get any profile information, e.g. using getAppliedStereotype on a Element. If i look into the .uml file of the Class-diagram i can find statements like this at the end.
<OWL:owlOntology xmi:id="_vjb6UOQPEd6IJsGhqErA_g" base_Package="_zJBy4OQNEd6IJsGhqErA_g"/>
and the urifragment in base_Package is corresponding to an element in my Class-diagram.
I know maybe i should do this in ATL. But i am quite good in java and have no idea of ATL so i want to try this in java.
Thx
Stefan
So what do i have to do to make getAppliedStereoType working?
[Updated on: Thu, 10 December 2009 11:21] Report message to a moderator
| Re: UML2API basics [message #503010 is a reply to message #502693] |
Thu, 10 December 2009 10:03   |
Junior Member |
Ok,
first, wrong forum i apologize, but i wont start a new thread somewhere else now and unfortunately i cant move it.
So now some more information on what i have already tried.
First of all, i think it has something to do with the paths and their registration, but i cant figure out what to register where.
Here is my .uml file i what to work with:
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:OWL="http:///schemas/OWL/_K1uRkOWWEd6M1cgfy9sNmg/9" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xsi:schemaLocation="http:///schemas/OWL/_K1uRkOWWEd6M1cgfy9sNmg/9 ../MetaModels/OWL.profile.uml#_K1x78OWWEd6M1cgfy9sNmg">
<uml:Model xmi:id="_6I-AYeWVEd6M1cgfy9sNmg">
<packagedElement xmi:type="uml:Package" xmi:id="_
eSa0OWVEd6M1cgfy9sNmg" name="DataValuePattern">
<packagedElement xmi:type="uml:Class" xmi:id="_ldhPkOWWEd6M1cgfy9sNmg" name="Entity"/>
<packagedElement xmi:type="uml:Class" xmi:id="_my9YgOWWEd6M1cgfy9sNmg" name="Quality"/>
<packagedElement xmi:type="uml:Class" xmi:id="_n7H6cOWWEd6M1cgfy9sNmg" name="Region"/>
<packagedElement xmi:type="uml:PrimitiveType" xmi:id="_rlO0sOWWEd6M1cgfy9sNmg" name="Value"/>
<packagedElement xmi:type="uml:Association" xmi:id="_yPma8OWWEd6M1cgfy9sNmg" name="hasQuality" memberEnd="_yPnpEOWWEd6M1cgfy9sNmg _yPoQIeWWEd6M1cgfy9sNmg">
<ownedEnd xmi:id="_yPnpEOWWEd6M1cgfy9sNmg" name="src" type="_ldhPkOWWEd6M1cgfy9sNmg" association="_yPma8OWWEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_yPoQIOWWEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_yPnpEeWWEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
<ownedEnd xmi:id="_yPoQIeWWEd6M1cgfy9sNmg" name="dst" type="_my9YgOWWEd6M1cgfy9sNmg" association="_yPma8OWWEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_yPo3MeWWEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_yPo3MOWWEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="_zdnGMOWWEd6M1cgfy9sNmg" name="hasRegion" memberEnd="_zdnGMeWWEd6M1cgfy9sNmg _zdntQuWWEd6M1cgfy9sNmg">
<ownedEnd xmi:id="_zdnGMeWWEd6M1cgfy9sNmg" name="src" type="_my9YgOWWEd6M1cgfy9sNmg" association="_zdnGMOWWEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_zdntQeWWEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_zdntQOWWEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
<ownedEnd xmi:id="_zdntQuWWEd6M1cgfy9sNmg" name="dst" type="_n7H6cOWWEd6M1cgfy9sNmg" association="_zdnGMOWWEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_zdoUUOWWEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_zdntQ-WWEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="_0EHskOWWEd6M1cgfy9sNmg" name="hasValue" memberEnd="_0EIToOWWEd6M1cgfy9sNmg _0EITo-WWEd6M1cgfy9sNmg">
<ownedEnd xmi:id="_0EIToOWWEd6M1cgfy9sNmg" name="src" type="_n7H6cOWWEd6M1cgfy9sNmg" association="_0EHskOWWEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_0EITouWWEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_0EIToeWWEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
<ownedEnd xmi:id="_0EITo-WWEd6M1cgfy9sNmg" name="dst" type="_rlO0sOWWEd6M1cgfy9sNmg" association="_0EHskOWWEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_0EI6seWWEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_0EI6sOWWEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="__MZokOWWEd6M1cgfy9sNmg" name="hasPart" memberEnd="__MaPoOWWEd6M1cgfy9sNmg __Ma2sOWWEd6M1cgfy9sNmg">
<ownedEnd xmi:id="__MaPoOWWEd6M1cgfy9sNmg" name="src" type="_my9YgOWWEd6M1cgfy9sNmg" association="__MZokOWWEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="__MaPouWWEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="__MaPoeWWEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
<ownedEnd xmi:id="__Ma2sOWWEd6M1cgfy9sNmg" name="dst" type="_my9YgOWWEd6M1cgfy9sNmg" association="__MZokOWWEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="__Ma2suWWEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="__Ma2seWWEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="_EmaaMOWXEd6M1cgfy9sNmg" name="hasPart" memberEnd="_EmbBQOWXEd6M1cgfy9sNmg _EmbBQ-WXEd6M1cgfy9sNmg">
<ownedEnd xmi:id="_EmbBQOWXEd6M1cgfy9sNmg" name="src" type="_n7H6cOWWEd6M1cgfy9sNmg" association="_EmaaMOWXEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_EmbBQuWXEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_EmbBQeWXEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
<ownedEnd xmi:id="_EmbBQ-WXEd6M1cgfy9sNmg" name="dst" type="_n7H6cOWWEd6M1cgfy9sNmg" association="_EmaaMOWXEd6M1cgfy9sNmg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_EmboUeWXEd6M1cgfy9sNmg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_EmboUOWXEd6M1cgfy9sNmg" value="1"/>
</ownedEnd>
</packagedElement>
<profileApplication xmi:id="_ZOTgsOWWEd6M1cgfy9sNmg">
<eAnnotations xmi:id="_ZO-2IOWWEd6M1cgfy9sNmg" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href="../MetaModels/OWL.profile.uml#_K1x78OWWEd6M1cgfy9sNmg"/>
</eAnnotations>
<appliedProfile href="../MetaModels/OWL.profile.uml#_0"/>
</profileApplication>
</packagedElement>
</uml:Model>
<OWL:owlOntology xmi:id="_brFFIOWWEd6M1cgfy9sNmg" base_Package="_-eSa0OWVEd6M1cgfy9sNmg"/>
<OWL:owlClass xmi:id="_vEkCUOWWEd6M1cgfy9sNmg" base_Class="_ldhPkOWWEd6M1cgfy9sNmg"/>
<OWL:owlClass xmi:id="_vpNAcOWWEd6M1cgfy9sNmg" base_Class="_my9YgOWWEd6M1cgfy9sNmg"/>
<OWL:owlClass xmi:id="_wNBfMOWWEd6M1cgfy9sNmg" base_Class="_n7H6cOWWEd6M1cgfy9sNmg"/>
<OWL:objectProperty xmi:id="_8Pz7oOWWEd6M1cgfy9sNmg" base_Association="_yPma8OWWEd6M1cgfy9sNmg"/>
<OWL:objectProperty xmi:id="_9I4RoOWWEd6M1cgfy9sNmg" base_Association="_zdnGMOWWEd6M1cgfy9sNmg"/>
<OWL:objectProperty xmi:id="_9z7ZwOWWEd6M1cgfy9sNmg" base_Association="_0EHskOWWEd6M1cgfy9sNmg"/>
<OWL:objectProperty xmi:id="_IQb04OWXEd6M1cgfy9sNmg" base_Association="_EmaaMOWXEd6M1cgfy9sNmg"/>
<OWL:objectProperty xmi:id="_JLM0AOWXEd6M1cgfy9sNmg" base_Association="__MZokOWWEd6M1cgfy9sNmg"/>
</xmi:XMI>
In the attachements you can find the OWL.profile.uml. its and UML profile for the OWL (Ontology Web Language) from the OMG. So it should be correct. And as far as i know working with it and ATL works.
As you can see there is a Profile applied, namely OWL.profile.uml and the href is correct relative to the .java and relative to the .uml files that uses the profile.
All i tied so far is:
- adding the file extension of profiles to the resourceSet.getPackageRegistry()
resourceSet.getPackageRegistry().put(UMLResource.PROFILE_FILE_EXTENSION, UMLPackage.eINSTANCE);
with no effect. not even a new entry in the registry.
- adding a new entry to the pathmap, but i dont really know how the first URI should look, because i cant just overwrite the entry set for UMLUMLResource.PROFILES_PATHMAP.
- last but not least i tried to load the Profile seperately, it works but has no effect on the getAppliedStereoType result. Still empty.
- I thought about just building a workaround for me, just getting the Profile-Elements by hand and crossreference them on my own, but i dont really know how to get them because in my resource they are present as
org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@72608760 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@1f57ea4a (name: objectProperty) (instanceClassName: null) (abstract: false, interface: false)) (mixed: [], anyAttribute: [base_Association=_yPma8OWWEd6M1cgfy9sNmg])
What ECoreUtil.Literals.xxx for AnyTypeImpl (it doesnt work through EClass) and how to get object of a specific type out of an Resource?
I hope this additional information helps to find a solution.
Thx Stefan
| Re: UML2API basics [message #503020 is a reply to message #502693] |
Thu, 10 December 2009 10:28   |
Ed Merks Messages: 24530 Registered: July 2009 |
Stefan,
Comments below.
Stefan wrote:
> project.
> tutorial.
> eclipse-plugin):
> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
You mention opening class diagrams. Do you really mean diagram files
are just UML resources themselves.
> URI uri =
> URI.createURI(" jar:file:/C:/eclipse/plugins/org.eclipse.uml2.uml.resources_ 3.0.0.v200906011111.jar!/ ");
File URIs for relative paths sound like a bad idea. Relative
references within those files just won't resolve properly. It's best to
use absolute paths with absolute URIs.
> my Class-diagram.
> Thx
> Stefan
| Re: UML2API basics [message #503032 is a reply to message #503010] |
Thu, 10 December 2009 10:32   |
Stefan,
Comments below.
Stefan wrote:
> Ok,
> </ownedEnd>
> </ownedEnd>
> </packagedElement>
> </ownedEnd>
> </ownedEnd>
> </packagedElement>
> </ownedEnd>
> </ownedEnd>
> </packagedElement>
> </ownedEnd>
> </ownedEnd>
> </packagedElement>
> </ownedEnd>
> </ownedEnd>
> </packagedElement>
> href="../MetaModels/OWL.profile.uml#_K1x78OWWEd6M1cgfy9sNmg "/>
> </eAnnotations>
> </packagedElement>
> </uml:Model>
> </xmi:XMI>
Again, it's likely that using a relative path for loading the resource
is contributing to the problem.
> resourceSet.getPackageRegistry().put(UMLResource.PROFILE_FIL E_EXTENSION,
I don't know why the profile extension would need to be registered as if
it were a package namespace.
That sounds like what would happen if the data isn't being recognized as
conforming to a specific model.
It's of course best to ask on the UML2 newsgroup.
> Thx Stefan
| Re: UML2API basics [message #600620 is a reply to message #503020] |
Thu, 10 December 2009 11:20  |
Junior Member |
That diagram thing was just a misunderstanding. But the Path issue works perfect for me. Maybe someone should put this into the standalone faq
thx you so much, tried this for two days.
Stefan
FUDForum. Page generated in 0.01788 seconds
