Home » Modeling » B3 » Problems with DS on startup
Problems with DS on startup [message #600279] Sun, 28 February 2010 06:42
Filip Hrbek is currently offline Filip Hrbek
Hi all,
I have a strange problem with launching our headless b3 application. Btw., headless buckminster suffers from the same error which is not fatal but puts an ugly error message in the error log.
The error is:
!ENTRY org.eclipse.equinox.ds 4 0 2010-02-28 12:27:37.724
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.equinox.internal.util.event; version="1.0.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolverError(AbstractBundle.java:1312)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureException(AbstractBundle.java:1296)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:319)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:369)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1069)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:554)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:461)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:246)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:442)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
It happens only the first time after installation. Following starts are ok.
I googled out some discussions about this but to be frank, it did not help me.
Some more details:
- even though this error appears in the log, all bundles finally resolve/start successfully
- I can't find any broken constraints in the runtime, all required bundles/packages are available
If I edit the config.ini file and replace
"osgi.bundles=reference\:file\:org.eclipse.equinox.ds_1.2.0.v20100125.jar@1\:start,reference\:file\: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100123-101 9.jar @1\:start"
with
"osgi.bundles=reference\:file\:org.eclipse.osgi.services_3.2.100.v20100108.jar@1\:start,reference\:file\:org.eclipse.equinox.util_1.0.100.v20090520-1800.jar@1\:start,reference\:file\:org.eclipse.equinox.ds_1.2.0.v20100125.jar@1\:start,reference\:file\: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100123-101 9.jar @1\:start"
everything works fine from the very beginning (even after fresh installation).
Does anyone know how to fix this problem without a need to provide customized config.ini?
Filip
Previous Topic:Aggregator with version range support
Next Topic:Helios release was successfully built with b3 aggregator
Current Time: Mon May 20 02:44:55 EDT 2013
Powered by FUDForum. Page generated in 0.02356 seconds
