| Re: TableCombo not showing up in Palette & CalendarCombo Bug? [message #547676 is a reply to message #547671] |
Mon, 19 July 2010 06:42   |
Ludwig Moser Messages: 204 Registered: July 2009 |
ok, i removed it from the ide.
added the jars now.
adding the components to the palette by hand.
0) right-click on the palette
1) import jar...
2) selecting the jar on FS.
3) message pops up that the MANIFEST.MF is incorrect/empty. -> show all classes - i select yes
4) pick the TableCombo.class as the class i want to add. -> OK
5) nothing happens.
when i do exactly the same with the CalendarCombo it shows up in my palette, so it cant be completely wrong what i do...
EDIT: i just saw in the palette manager that the TableCombo is marked as
java.lang.ClassNotFoundException: org.eclipse.nebula.widgets.tablecombo.TableCombo
but its selected out of the ide which means it should only show what really exists...
come on man.
i just checked:
1) palette manager
2) import jar
3) do the exactly same stuff as above! and now it works
wtf?
so the only thing left is the nullpointer exception in the CalendarCombo...
PS: Thanks for your patience...
[Updated on: Mon, 19 July 2010 06:49] Report message to a moderator
FUDForum. Page generated in 0.02171 seconds
