Home » Eclipse Projects » EPF » find referencing elements
find referencing elements [message #599167] Wed, 10 February 2010 12:20 Go to next message
Eclipse User
Originally posted by: eclipse.d70.nl
Does any of yous know of a way to find where an artifact is referenced?
Say I have an artifact called SRS which has changed somewhat over time.
I want to check all the elements referencing SRS for errors. How to find
them?
Mic
ps I know a workaround: delete the artifact, epf will warn with the
message "The element(s) you are about to delete are still being
referenced by..", giving the list that I need in textual format. So epf
is capable of identifying them. Surely there must be a way to query the
methods without a destructive side effect..
Re: find referencing elements [message #599263 is a reply to message #599167] Fri, 12 March 2010 12:30 Go to previous messageGo to next message
Bruce MacIsaac is currently offline Bruce MacIsaac
There is a references view, which shows all the elements referenced by the element.selected in the library.
Re: find referencing elements [message #599278 is a reply to message #599263] Tue, 16 March 2010 06:33 Go to previous messageGo to next message
Eclipse User
That sounds useful.. where can i find it? If i search for 'references'
in window->show view->other, it finds nothing..
Mic
Re: find referencing elements [message #599356 is a reply to message #599167] Thu, 22 April 2010 05:16 Go to previous message
Leeeee  is currently offline Leeeee
The preview tag page shows the roles and tasks which referenced this work product.
Hope it helps.
Previous Topic:find referencing elements
Next Topic:why base task and assign task?
Current Time: Mon Jun 17 23:41:30 EDT 2013
Powered by FUDForum. Page generated in 0.02835 seconds
