Home » Eclipse Projects » Nebula » Nebula grid - get selected values
Nebula grid - get selected values [message #595852] Fri, 07 August 2009 03:35 Go to next message
Marcel A. is currently offline Marcel A.
i use the nebula grid component to load spreadsheet values.
In some operations i need to get all selected values which can be in one block (as usual) or in many blocks (using control and/or Shift).
If i want to get all values in many blocks (using the Control-key: select one column->pressing Control->select another column)
i get some values twice (the first number in the spread in the next selection block).
i use:
Point[] sel = grid.getCellSelection();
String[] data = new String[sel.length];
for (int i = 0; i < sel.length; i++) {
data[i] = grid.getItem(sel[i].y).getText(sel[i].x);
System.out.println(data[i]);
Is this a normal behaviour of nebula grid?
With kind regards
Marcel
Re: Nebula grid - get selected values [message #598337 is a reply to message #595852] Fri, 02 October 2009 04:08 Go to previous messageGo to next message
I could remove double entries of the selection as a workaround
but is this a bug of the Nebula grid component?
I also want to remove columns from a selection reliable.
Any information is appreciated!
Re: Nebula grid - get selected values [message #598340 is a reply to message #598337] Fri, 02 October 2009 07:11 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Most likely but I don't have time to work on it :-(
Tom
Re: Nebula grid - get selected values [message #598404 is a reply to message #595852] Mon, 12 October 2009 07:37 Go to previous message
My workaround for the moment is that i do not permit a selection
(delete selection) if a drag event occurs and the controll key
is pressed. This works so far for my purposes.
Previous Topic:[Grid] cellSelection and rowSelection
Next Topic:Stand alone analog clock from CDateTime?
Current Time: Sat May 18 15:45:23 EDT 2013
Powered by FUDForum. Page generated in 0.01535 seconds
