| How to view tables, stored procedure etc in DTP [message #596574] |
Wed, 07 October 2009 06:15  |
No real name Messages: 8 Registered: September 2009 |
Junior Member |
Hi Guys,
I have installed eclipse galileo 3.5 for j2ee. I have installed and configure mysql database in eclipse too. I pinged the database and connected successfuly.
I can create database and create tables etc in sql scrapbook, but in database development prespective when go under the schemas then try to expand the folders for tables, user defined function, procedures etc found nothing.I can't see the tables I created under table folder.
I have took the screen shot and uploaded - Where you can see i can't expand the nodes of folder, procedure etc to see my tables etc.
Please tell me what I am doing wrong or missing some thing.
| Re: How to view tables, stored procedure etc in DTP [message #596580 is a reply to message #596574] |
Wed, 07 October 2009 15:03   |
Brian Fitzpatrick Messages: 495 Registered: July 2009 |
Can you tell us what database you're using, what profile wizard you used
(i.e. generic JDBC, or something else), and what JDBC driver you're using?
--Fitz
virkjay@hotmail.co.uk wrote:
> Hi Guys,
> Thanks
| Re: How to view tables, stored procedure etc in DTP [message #596612 is a reply to message #596574] |
Thu, 08 October 2009 21:17  |
Junior Member |
I am using Mysql 5.1 and plugin with Connector J with following jar file - mysql-connector-java 5.1.10 bin.jar.
Driver type used is - MySQL JDBC Driver 5.1
I had gone into (eclipse) window - prefrence, under driver definition added the Mysqljdbc driver 5.1 and mysql-connector-java 5.1.10 bin.jar.
Under database development added new connection configure the connection and connect it and pinged successful but tables are not showing.
Please tell me where I am going wrong or what to do this work properly.
FUDForum. Page generated in 0.01562 seconds
